ACT Clutchs and wear on the car
Old Jan 10, 2003 | 09:20 PM
Phaze2 Mike's Avatar
Default ACT Clutchs and wear on the car
Hey, im running an ACT xtreme PP w/6 puck no spring disc. As of now, my tranny is great, but i have heard a few rumors that clutch setup eats trannies. Also, heard that it loosens intermediate shafts and rear mounts. Any truth to this? Being as i have never had an aftermarket clutch and this one came with the motor, im not that educated on the subject. I mean, logically, i suppose it could be true, but any non ******** replies are very much appreciated.
Old Jan 11, 2003 | 08:04 AM
Default Re: ACT Clutchs and wear on the car (Nextekhatch)
anyone?
Old Jan 11, 2003 | 08:17 AM
eg6ajk's Avatar
if you do burn outs with slicks, or speed/power shift something must give. stock clutch would usually slip in these situations, but a race clutch does not do that thefore all the vibration and stresses are put on the motor and tranny. blown diffs or other internal tranny problem can be then traced to that.
if you are not running a setup that requires that much of holding capacity. then keep using the Xtreme pressure plate but change to a stock disc. this way you get a little more holding capacity and less fade
Old Jan 11, 2003 | 08:30 AM
b16 matt's Avatar
Default Re: ACT Clutchs and wear on the car (eg6ajk)
OH Yeah If your not running a sprung hub on a daily driver by by trainy. I run a sprung hub. unless you plan on not driving the car on a daily basis go sprung.
Old Jan 11, 2003 | 08:31 AM
b16 matt's Avatar
Default Re: ACT Clutchs and wear on the car (evilb16)
mine is an xtreme pressure plate, and organic pucks, its still sprung.
Old Jan 11, 2003 | 01:58 PM
Im pretty easy on it, but i guess when the disc goes (i estimate a few months) Ill get a street/strip disk with springs. thanks
Basilias
May 25, 2010 12:34 PM
EK k kay
Apr 17, 2006 08:55 AM
9kB20
17
Oct 5, 2005 12:08 PM
dbman96
May 15, 2002 05:44 AM
OPTIMUS
12
Apr 22, 2002 11:33 AM
