morning starts rough please help
when i go out to start my car in the morning it doesn't start very well. it kicks over then studders a little bit then sometimes it dies or starts to idle fine. this only happen in the morning. i have a 89 crx si with 133000 miles. what can be wrong with it
you need to put LSVTEC in your crx and that would fix all your problems
you only have few things that may be the problem tune up battery or a starter good luck
maybe your IACV its bad or unplugged...
sounds like ur engine its not getting enough air in idle and its dying...
either that or u have a vaccum leak
IACV is a stong possibility as previously mentioned. Dirty cap, plugs, wires, fuel filter, all simple things to check first. More serious possibilities, fuel relay switch(probably not though), blown headgasket, crappy compression, clogged injectors. Some ideas anyhow.
Do a compression check if you can, rule that one out first.
SlimJim25
Apr 17, 2013 01:09 PM
crazyboy
42
Jan 30, 2010 10:40 AM
