itr rear seat install
I just picked up a set of itr rear seats.
- the backing of the seat goes in with out a problem
- but the bottom loop holes dont match for ****.
- when i set the bottom of the seat down like it would sit. the loop holes look like they are holding up the seat? like it sits high or somthn.
does anyone have pics of these in your hatch? 92-95
thanks!
. i remember someone had a set in there hatch that lookd stock.
thanks!
I am not sure what you are trying to say but the bottom part on integras doesn't clip in unfortunately. At least mine didn't. Just run the seat belt buckles through and that should hold it in place. Good luck.
thanks!
thanks!
If it's a USDM seat, the lower half off the rear seat will not fit in the hatchbacks. The integra one is too short and not wide enough. I'm in the process of getting a civic restitched to black and red....blah blah yeah its not JDM but at least it will fit and match my interior. That's the best help I can give you.
I have the bottom in my 5th gen hatch but there are goin to be gaps on the sides. It will not fit perfectly. I just used the good old zip ties to hold the bottom part it. I think that's about all you could do since the foam is shaped to fit an integra.
- LoL - db8
May 18, 2008 07:46 AM
