AC in b16a swap?
Old Jan 10, 2003 | 02:16 PM
unabonger's Avatar
Default AC in b16a swap?
Do you have to take out the AC when doing a B16a swap into a crx si? or you can do the straight swap and still have AC? Sorry for the noob question this is my first swap. Thanks!
Old Jan 10, 2003 | 02:17 PM
MaaseyRacer's Avatar
Default Re: AC in b16a swap? (unabonger)
hasport.com has a mount that will allow you to use your old AC
Old Jan 10, 2003 | 02:42 PM
unabonger's Avatar
Default Re: AC in b16a swap? (MaaseyRacer)
Would it be better just to get a B series AC compressor that will fit then paying $180 for that bracket? or are there any other options then not having AC. Thanks.
Old Jan 10, 2003 | 04:04 PM
unabonger's Avatar
ttt
Old Jan 10, 2003 | 04:09 PM
unabonger's Avatar
I know someone here has a b16a with AC in there CRX/EF Civic. Share the knowledge please.
Old Jan 10, 2003 | 04:11 PM
bryant's Avatar
I dont think the JDM A/C will work. but im not real sure.
Just get the bracket and use your USDM A/C on your JDM motor.
Old Jan 10, 2003 | 04:41 PM
Bs's Avatar
Bs
Default Re: AC in b16a swap? (Bryant)
I dont think there are any b series brackets that you can use, i think i heard of one bracket that lines up on 2 of the 3 bolts but im not sure, the best and easiest thing to do is get the custom bracket. If you search im sure there are a lot of topics about this post.
Old Jan 10, 2003 | 05:07 PM
unabonger's Avatar
Default Re: AC in b16a swap? (B_s)
Ok, its starting to look like the HASport bracket is the ONLY option to having AC in a B16a CRX. I was thinking more like getting a B-Series AC Compressor and using that in place of the D-Series AC Compressor. B-Series such as the DEL SOL DOHC VTEC one. I'm not sure if its the same as the JDM B16a brackets though. Oh well thanks for your replies. If anyone has anymore comments about this your welcomed.
Old Jan 10, 2003 | 06:14 PM
88crxvtec's Avatar
I have the AC bracket but it won't work due to clearancess.....will have a 6month old hasport AC bracket if u wanna buy it ( sorry I know its not a buy/sell) I am going turbo. IT worked great. Have u already blown the AC Charge?
Old Jan 10, 2003 | 07:37 PM
Eggman's Avatar
supposedly you don't have to remove the a/c to do a swap. but in an ED it's so tight you might need the room.
your options:
- place racing bracket
- hasport bracket
- hcp bracket
- mickey mouse a b-series bracket to work, but who knows how long that might last. only like 2 of the 4 bolts will line up, i think.
you cant use the SiR bracket cause the d-series compressors and b-series compressors are different. sure you can bolt the SiR bracket and compressor to your b16, but then you can't use any of the oem lines.
*keep in mind, if you're using a chipped ecu you may have a very low idle when the A/C is on. hth.
Old Jan 10, 2003 | 08:07 PM
unabonger's Avatar
Default Re: AC in b16a swap? (Eggman)
WOW, thanks for all the info Eggman. My mind is now made up I'm definitely going for the aftermarket bracket.
Old Jan 10, 2003 | 11:19 PM
JDMCRX's Avatar
I have Place racing mounts to put ac in u have to use ur dseies and use a fabed up mount cause the lines are differenet
Old Jan 11, 2003 | 12:30 AM
DrRoboto's Avatar
Default Re: AC in b16a swap? (JDMCRX)
Uhm, I can't understand what that last guy was trying to say, so here's the low-down on the Place racing bracket... they have two different styles, they will let you use the A/C compressor and lines from your old engine on your b16. no changes necessary, but you do need to shell out $180 for it and make sure you know which a/c compressor you have. Works great for me, very solid. I highly recommend it.
Old Jan 11, 2003 | 05:48 AM
88crxvtec's Avatar
Default Re: AC in b16a swap? (DrRoboto)
I have the hasport, nice billet peice and my compressor bolted right up using stock lines. Very good quality and no problems. I will be getting rid of it now that my f-max kit is coming.
EFin Baby J
Jun 30, 2011 11:42 AM
Jap_Spec_Imports
Mar 15, 2009 01:13 PM
crazyguy
Aug 13, 2007 12:39 PM
flipn0y
Jun 2, 2002 03:13 PM
