HELP!! Cant figure out where leak is??
I just installed a new headgasket on my ls/vtec and when i started it up nothing leaks. But when the car gets warmed up i see oil dripping from under the cam gears. So i put some high temp silicone on the corners of the valve cover and waited approx 14 hours and started it back up. After about 5-10 mins of idleing I saw oil dripping again from under the cam gears.
Could it be my cam seals????
Or is it maybe the silocone didnt fully dry and it gets melted when the car gets warmed up???
Please help me I miss my LS/VTEC
TIA
-Brian
TIA
-Brian
We followed the bolt pattern from the helm on tightening and looosening
we also followed all torque specs also
Also the head is only approx 600 miles old
-Brian
-Brian
I see oil dripping down from behind the cam gears not inbetween the head and the block
hmm.. is the head gasket seated correctly?
do you see the oil coming from between the head and block? or valve cover and head?
EDIT: I meant oil seal not cam seal
-Brian
-Brian
Did you put Hondabond around the center (near the outter endcaps) on the valvecover gasket?
[Modified by HT Kleenex, 6:28 PM 1/10/2003]
vtec69
Jan 10, 2003 05:31 PM
