Where does YOUR temp gauge needle usually sit?
Old Jan 10, 2003 | 11:08 AM
Quik89Si's Avatar
Default Where does YOUR temp gauge needle usually sit?
I've been thru some overheating issues with my car, and I noticed that the temp gauge needle seems to sit higher than it used to, although it doesn't overheat anymore.
It now usually sits just a tick below horizontal, and you can barely see the top of the little curley thing at the bottom of the little symbol in there. It doesn't get up to any of the lines.
Where do yours sit?
Thanks in advance -
Alex
Old Jan 10, 2003 | 11:16 AM
FourthGenHatch's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (Quik89Si)
Like 1/3 up all the time. The thermostat isn't very accurate so there could be a 40* difference and it would sit at the same spot.
ricodemus's Avatar
Mine use to jump all over the place, sit at 1/3, then shoot up to 3/4 I figured I had a screwy temp sensor or something. Swapped in the b16, realized my radiator went to hell and bought a Fluidyne. It sits just a tick below horizontal now, but it doesn't move no matter the weather or how I'm driving once it's warmed up.
Old Jan 10, 2003 | 11:20 AM
ScottEK's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (ricodemus)
After taking the A/C radiator out my temp gauge rarely leaves cold.
Old Jan 10, 2003 | 11:35 AM
Quik89Si's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (beta13)
Okay, now I know my car has a separate fan for the A/C but I did NOT know there is a separate radiator. My Si just has a single radiator that goes all the way across the front of the car. Is this second rad on all CRX/EF or just certain ones, like maybe only DX or HF or something?
Thanks for the help. Keep it coming!
Alex
Old Jan 10, 2003 | 12:13 PM
Vinceg99's Avatar
Mine sits a tad below horizontal. As for the A/C "Radiator" I am almost positive that any Honda with A/C has the second one which I believe is the A/C drier or condensor?? Not sure I get some of the componets of the system confused so anyone that knows if thats what it called or what it is actually called that would be nice to know??....
Old Jan 10, 2003 | 12:32 PM
Driven's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (Vinceg99)
I'm usually idling at 180-185 degrees.
Old Jan 10, 2003 | 01:02 PM
ScottEK's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (Driven)
My Si has the second a/c one, I'm going to be working on another 91' CRX Si tonight, I'll tell you if it has it. I'll have two complete A/C systems if anyone needs parts.
Old Jan 10, 2003 | 01:16 PM
G2turbo_terror's Avatar
my former integra and my civic both sit just a tick below horizontal once it warms up, no matter the weather conditions. (both had AC if it matters)
Old Jan 10, 2003 | 02:00 PM
importfan85's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (G2turbo_terror)
Mine now sits just a tick below horizontal. When I had a cracked radiator, it sat at horizontal or just a tick above.
Old Jan 10, 2003 | 03:11 PM
TRE_'s Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (importfan85)
Mine usually sits about 2~3 ticks below horizontal. I'm running an integra rad. w/ redline water wetter, antifreeze and water. Engine is a ZC.
Old Jan 10, 2003 | 03:16 PM
slowman's Avatar
I took way too long
Default Re: Where does YOUR temp gauge needle usually sit? (glowing_rotors)
Mines usually here:
Old Jan 10, 2003 | 03:27 PM
USDM 4G VTEC's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (slowmanEF)
dude i love the photoshop work u do
cant tell its a BMP done with Microsoft Paint lol
ill give u a cd with photoshop in it when i send u the getaway in stockholms video
anyways in my car sits just a lil higher than slowman's draw
[Modified by JDM EF9, 7:27 PM 1/10/2003]
Old Jan 10, 2003 | 03:52 PM
EG8R's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (JDM EF9)
Just under half
Old Jan 10, 2003 | 03:55 PM
shorti's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (mr. skelly)
Just under half
Old Jan 10, 2003 | 04:11 PM
keebler65's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (shorti)
just under half is the max its ever gone. in the winter its about 1/4 up and on really cold days its off the scale (on the cold end of course). i also block half the radiator with cardboard or it'd never get close to operating temp.
Old Jan 10, 2003 | 08:59 PM
Quik89Si's Avatar
Mines usually here:
It's sdrawkcab.
But thank you for the very professional and clear illustration
Oh, and mine's never any different depending on weather. Cold, hot, whatever - always the same. But the only time the fans have come on recently were today, one of the hotter days this winter.
Thanks for all the replies. I knew I could count on you guys!!
Alex
Old Jan 10, 2003 | 09:09 PM
rice_classic's Avatar
Alex
It has to have it.. it's called a condensor.
Old Jan 10, 2003 | 09:54 PM
Quik89Si's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (rice_classic)
How big is it? Where is it exactly?
My CRX is at another location, so I can't go outside and look...otherwise I would.
Thanks again!
Alex
Old Jan 10, 2003 | 10:09 PM
the DR.'s Avatar
the condensor is usually in front of the radiator, you'll see it through the 'grill' in front (if you have A/C that is) looks like another radiator
and my temp gauge is a tad below half(horizontal) just like in that awesome picture posted above
Old Jan 10, 2003 | 11:33 PM
rasta420's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (SlicedBread)
during the summer, it usually sat a tick below the middle.
but now in the colder weather, if i warm the car up and dont move it, it gets to about 2 ticks below middle. then when i start driving, it will get colder! sometimes even below C. then when i stop moving it goes back up...
anyone have any idea what this could be? during the summer it was a constant temp.
Old Jan 11, 2003 | 08:47 AM
Ef Whore's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (rasta420)
it should sit a little below horizontal---if yours keeps changing try replacing the coolant temp. sensor.
Old Jan 11, 2003 | 10:26 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Where does YOUR temp gauge needle usually sit? (Ef *****)
i installed a water temp on mine. Its useually sits round 180 F. If it gets worked it sometimes jumps to just a lil over 200 deg F.
Blaze
Old Jan 11, 2003 | 11:03 AM
No More Civic's Avatar
Default Re: Where does YOUR temp gauge needle usually sit? (Blaze45)
Mine only works about once a month. I really need to quit being lazy and get a new one.
FREELIGIOUS
Jul 19, 2010 04:28 PM
Paulie10
Jun 13, 2009 03:17 PM
stocker2shocker91
Mar 24, 2008 01:19 PM
Mikey
Jan 8, 2005 08:03 AM
mattmw88
Oct 19, 2004 09:36 AM
