New HKS headlight bulbs just got em!!!!!!!!!
Old Jan 10, 2003 | 07:14 AM
DeDonDeRosa's Avatar
Default New HKS headlight bulbs just got em!!!!!!!!!
i just wanted to tell you about the new HKS headlight bulbs i just put them on my car and i wanted to say that there very nice and crystal clear. I think that they are the closest bulbs to that HID look. Anyone else got these bulbs?? I u want a set of bulbs i recommend these ones cause they are bright and clear you wont be disappointed.
Old Jan 10, 2003 | 07:32 AM
LODOSS's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (DeDonDeRosa)
what other bulbs have you used before?? i have used a lot and have good amount of knowledge about them but i have'nt seen the HKS in action. so i am wondering if you can compare them to some of your other bulbs etc. man i feel like such a ricer =[
Old Jan 10, 2003 | 07:55 AM
Ohlias's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (LODOSS)
Are these bulbs coated with a "color"?
Most afterarket bulbd I've seen have some kin dof coating on them and lose atleast 15% light over OEM stock (Even PIAAs)...
PIAAs cost Almost $200 CDN and you lose light over stock...
How much are the HKS and has anyone tested them?"
Old Jan 10, 2003 | 08:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
i'd like to know who makes these bulbs that HKS puts their name on.
Old Jan 10, 2003 | 08:25 AM
Understeer's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (PatrickGSR94)
Share your wisdom and post pics so others can see and decide.
Old Jan 10, 2003 | 10:46 AM
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (Understeer)
well my friend has the silverstars and i like these better the bulbs for a set are 44 bucks from http://www.optauto.com
Old Jan 10, 2003 | 12:58 PM
Community Builder
55W = 120W... what a crock, what the hell does that mean anyway?
HKS Hi-Power bulbs emit a 120W bright white beam for an HID look.
HID headlights only draw 35W in the first place. Wattage is a measure of power consumption, not light output. I laugh in the face of all bulbs with those kinds of claims on the package.
Old Jan 10, 2003 | 02:03 PM
55 watt is what it takes to power and emits 122
Old Jan 10, 2003 | 04:36 PM
Community Builder
sorry, wattage is not any sort of measure of light output. Stock 9006 draws 55W nominal (actually 51W) and puts out ~1000 lumens. Regular 9005 draws 65W nominal (actually 60W) and puts out ~1700 lumens. 4300K HID draws about 35W and puts out ~3200 lumens. You cannot use wattage to measure light output. It's like trying to use liters or cubic inches to describe the power output of an engine, it just doesn't work.
Old Jan 10, 2003 | 05:28 PM
GSRaCeRbOI's Avatar
haha HKS makes light bulbs now?
Old Jan 10, 2003 | 07:15 PM
mugenracer's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (GSRaCeRbOI)
where did you get them from, how much did they cost and what is the light from them like?
I always considered HKS as a company that made performace parts/electronics for JDM cars, i cant imagine them actaully testing/producing bulbs, more than likely theyre just a generic brand with HKS packaging. i got tired buying these so called HiD look bulbs, they were all the same, basically... crap lighting, very short life and fancy packaging. stick with OEM and you wont go wrong. I still have in the origianl bulbs that came in my car from the factory in 1994, they still give a reasonably good light, they dont shatter after 3 weeks and they cost **** all to buy!
Old Jan 10, 2003 | 07:56 PM
BoM's Avatar
BoM
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (mugenracer)
nothign can compare to real HID's
not even those bulbs. consider getting HID's
after your bulbs blow. time and time again.
Old Jan 11, 2003 | 12:55 AM
IntEGNYC's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (BoM)
PatrickGSR94 has got the right info. To those who want the xenon bulbs, come back and post results when your lamps start cracking or melting from the "High watttage" bulbs.
Don't believe the packaging when they say HID look. Looks nothing like HID
Old Jan 11, 2003 | 04:14 AM
EKB18BPR3's Avatar
my bulbs are better than all of yours combined. i get mines from WALMART!!
Old Jan 11, 2003 | 11:39 AM
95 Gizzer
Guest
Posts: n/a
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (dniedacess)
Yeah I have the Walmart brand bulbs in my car and they own
Old Jan 11, 2003 | 10:01 PM
2k1_ITR_0736's Avatar
Default Re: New HKS headlight bulbs just got em!!!!!!!!! (95VTECGSR)
eyah i feel that stuff, i got the piaa superwhites, and those bastards are 75$ a set. thats half an HID kit for my integra. 2 sets in there $150+tx
Old Jan 11, 2003 | 10:09 PM
TheGSRGuy's Avatar
If these are anything like the typical garbage headlamp bulbs I see for sale, you wasted your money. Color is nothing in headlamps. Your eye is not as sensitive to blues and purples, which is why those fake-HID headlamp bulbs do nothing (it is actually most sensitive to yellows and greens). The reason HID is so much better than an incandescent bulb is because it throws roughly 3 times the light (lumens) on the road.
If you want good headlamp bulbs, try the Sylvania XtraVisions ($13) or the Silverstars ($25).
EDIT: I see the box says 55w->120w. Sorry folks, but a 55w bulb is 55w. PIAA pulls the same crap. A 55w bulb cannot put out 120w of light. Wattage is irrelevant to light output anyways, lumens is where the money is.
[Modified by TheGSRGuy, 7:12 AM 1/12/2003]
vtec2K9
Lighting
Jul 3, 2008 08:44 PM
Jaypee
Oct 6, 2005 02:31 AM
bwalter182
Apr 22, 2004 11:41 AM
Train
Dec 25, 2003 09:46 PM
TypeR1558
Jun 20, 2001 02:34 PM
