... displacement question (b18c1, 84mm bore, ls crank)
... i used the c-speed calculator for the b18c1 with an 84 mm bore (and got 1933.1688)... but how much more displacement will the ls crank give me???
... also, what do you guys think?... is it worth it to switch to the ls crank when i rebuild?... or should i just stick with the gsr crank?... lemme know... thanks...
i have a gsr block with 84mm darton sleeves and i used the stock crank and trust there is more than aduquet (sp?) power, so i woul.dnt worry too much.
joedeezy
Oct 18, 2008 02:53 PM
