Honda S2000 Honda S2000
kg/mm springs
Old Jan 10, 2003 | 01:16 AM
Stag 2000's Avatar
Default kg/mm springs
Anyone have em, or familiar with them. Most feedback I've heard is they retain stock ride better than any spring (non-coilover) available. Any opinions? Other than not to lower it at all!
Old Jan 15, 2003 | 11:33 PM
Spikey's Avatar
Default Re: kg/mm springs (Stag 2000)
almost everyone who has used kg/mm springs has a favourable impression of them
the ride quality is very good, it doesn't have the harshness typically associated with lowering springs such as H&R. at the same time, they perform very well
Old Jan 16, 2003 | 01:30 AM
Stag 2000's Avatar
Default Re: kg/mm springs (Spikey)
Thats what I heard. Buyer beware. Nuespeed springs are awful.
Old Jan 22, 2003 | 12:48 PM
.RJ's Avatar
.RJ
kg/mm is a spring rate, identical to lbs/in. It is a measure of how stiff the spring is, not a brand or type. For instance, if you compressed a spring with 400lbs of pressure and it compressed 1 inch, your spring rate is 400 lb/in. Same for kg/mm.
Old Jan 22, 2003 | 01:16 PM
AJ PwR's Avatar
Default Re: kg/mm springs (Indecisive.RJ)
He is referring to the Japanese spring manufacturer called KG/MM sometimes also called KGM
Old Jan 22, 2003 | 08:31 PM
.RJ's Avatar
.RJ
Default Re: kg/mm springs (AJ PwR)
Interesting, that easily leaves room for misinterpretation
Old Jan 23, 2003 | 03:45 AM
cjb80's Avatar
I have them in stock, contact me at chris@bulletproofautomotive.com
Thanks
Chris
Old Jan 23, 2003 | 11:03 PM
v67-gsr's Avatar
Default Re: kg/mm springs (cjb80)
Of all the aftermarket spring, kg/mm is the best you can buy (beside coilover set). And the DR line is the way to go. It combine two spring into one. ride is extremely good, but when you push it, it will never disappoint you.
Old Jan 25, 2003 | 08:54 AM
kwando's Avatar
Default Re: kg/mm springs (v67-gsr)
I have them and they ride really nice. Very close to stock. Using them with the OEM struts and can't complain. Get the DR-21 Race Version, that is what I have.
Old Jan 27, 2003 | 03:02 PM
Stag 2000's Avatar
Default Re: kg/mm springs (kwando)
They make race and a sport spring. Whats the drop on race?
Old Jan 28, 2003 | 11:36 AM
spoonek4's Avatar
Here is how an Ap1 would look like with Kg/mm DR Racing springs+OE dampers w/ 18" OZ Superleggeras...
Here are some useful sites:
http://www.kgm.co.jp http://www.aj-racing.com http://www.ipsracing.com http://www.randdmotorsports.com
Old Feb 5, 2003 | 09:43 AM
kwando's Avatar
Default Re: kg/mm springs (spoonek4)
Good choice in rims.
Old Feb 20, 2003 | 07:41 PM
Turbo'dMex-A-Keen's Avatar
Dang thats the nicest s2k i ever sawed hahaha
sakasaku
May 22, 2008 06:56 PM
Naturally Aspirated
Sep 21, 2004 06:23 PM
