Changing rear brake pads on a 93 Si hatch
Old Jan 9, 2003 | 10:43 PM
Nocturnal's Avatar
Default Changing rear brake pads on a 93 Si hatch
Rear disc brakes. How hard is it? Do I still need the C-Clamp to push the piston back in? I read that I will need to turn something clock wise? What is this? I'm only doing my rears tomorrow. I don't want to be up **** creek when this happens.
Old Jan 9, 2003 | 10:55 PM
mantic6t9's Avatar
Default Re: Changing rear brake pads on a 93 Si hatch (psychotic)
1. Remove the two bolts
2. Pull caliper from rotor
3. Remove old brake pads
4. Turn the piston back into the caliper like a screw. ( I use needle noes pliers )
5. Install new brake pads
6. line up the slots in the piston with dimple on the back of the inner pad
7. Slind caliper over rotor and new pads and make sure everythink lines up
8. Torque the bolts down and your done.
Old Jan 9, 2003 | 11:02 PM
Nocturnal's Avatar
Default Re: Changing rear brake pads on a 93 Si hatch (mantic6t9)
What if I don't own a torque wrench? Then what? Can I impact it down?
Old Jan 9, 2003 | 11:05 PM
mantic6t9's Avatar
No.... If you don't have one why not buy one. You can get one for small jobs at sears for $20. Do not use an impact gun. If you have to get by without a torque wrench then just make sure they are tight. I think it's only like 38ft lbs anyway.
[Modified by mantic6t9, 2:05 AM 1/10/2003]
lowered94accord
Apr 19, 2007 11:46 AM
decode22
Oct 29, 2005 07:15 PM
sleepyhamsterlx
Dec 29, 2003 03:12 PM
J T*
Apr 23, 2002 03:42 PM
cecknight
Sep 27, 2001 04:35 AM
