What blow off valve for 600+ hp??
I currently am running an hks ssqv blow off valve on 26 psi of boost and 500+whp. Most people are shocked that it even holds that much boost but I cant complain as of yet. my new goal is over 600hp. Would it be recommended to change to a godzilla bov or greddy type r stiff spring?? Turbonetics has a new raptor BOV. Anyone using this yet??what would you guys running 600+whp recommend for a blow off.
We run a tial bov and it holds over 40psi for sure!
The tial bov looks to be a very good bov but I'm not too sure how good it works under some regular driving sence that spring they got in there is stiff as hell...
Jojo Callos actually runs that new Turbonetics Bov on his car, so it must be working right for him..
Adi
used to run the tial on my old hybrid accord.
now running the hks ssq unit.
love both but i believe the tial is the better choice for high boost applications.
I run a Turbo XS Type S on my manifold and a Tial 35mm on my charge pipe
That's the right way to do it, right?
Son of a bitch! That's why I had to weld that 1" flange onto that 1.5" hole in the turbo manifold! I wondered what those bolt holes were for!!
Sure, holding back that pressure doen't seem crazy.
But, can it dump quick enough...
You might try using 2 of them.
Look at some of the Turbo V8 and Big power Supras they use 2 to make sure
to get enough flow.
You may want to try a Turbonetics Godzilla... or 2
Jeffrey Atwood
[Modified by Jefnes, 1:38 PM 1/10/2003]
to get enough flow.
Jeffrey Atwood
ThePro
Nov 10, 2004 09:36 AM
