Are theses NGK spark plugs good for the R?
Old Jan 9, 2003 | 08:50 PM
B2FiNiTY's Avatar
Default Are theses NGK spark plugs good for the R?
Part #: 2975zfr7f-11
Non-platinum. I would like to get the stock ones but I can get these for a good deal. Will it be fine?
Old Jan 9, 2003 | 09:48 PM
sgT's Avatar
sgT
Default Re: Are theses NGK spark plugs good for the R? (B2FiNiTY)
might be a step too cold. but i would think they would be fine. not as good as stock though
Old Jan 9, 2003 | 09:54 PM
TypeR 599's Avatar
Default Re: Are theses NGK spark plugs good for the R? (sgT)
would those be better than stock with spoon cams?
Old Jan 9, 2003 | 10:10 PM
sgT's Avatar
sgT
Default Re: Are theses NGK spark plugs good for the R? (TypeR 599)
no
Old Jan 9, 2003 | 10:31 PM
B2FiNiTY's Avatar
I'll pass on these then.
Old Jan 9, 2003 | 10:43 PM
sgT's Avatar
sgT
BKR7EVX11 and their iridium equivelant are not too bad in price.
but for stock motors i would recommend a 6 over the 7
Old Jan 9, 2003 | 10:46 PM
TypeR 599's Avatar
what kind of setup would be good for that kind of setup? i know it works great in supras and mr2 turbos..
Old Jan 9, 2003 | 10:49 PM
B2FiNiTY's Avatar
So the higher the number = the colder it is. Good to know
Old Jan 9, 2003 | 11:51 PM
spoon_ek9's Avatar
why? i thought 7 is better in track condition.
Old Jan 10, 2003 | 06:03 PM
fukaintmuven's Avatar
Default Re: Are theses NGK spark plugs good for the R? (spoon_ek9)
what about those denso iradiums... i need to know before i install them and blow my engine..... o and the colder it is the better for high compression or boost....
Old Jan 10, 2003 | 07:38 PM
primoEF's Avatar
Default Re: Are theses NGK spark plugs good for the R? (fukaintmuven)
denso
NGK
Old Jan 10, 2003 | 09:30 PM
RTW DC2R's Avatar
Default Re: Are theses NGK spark plugs good for the R? (EFDog)
stock ITR's or non platinum one step colder for higher compression
Old Jan 10, 2003 | 09:46 PM
spoon_ek9's Avatar
denso
NGK
care to explain?
i use it and i like it alot. i am using IK24 right now.
Old Jan 13, 2003 | 09:23 PM
Mr.Integra's Avatar
i like the densos a lot too..
just too expensive for my taste
Old Jan 13, 2003 | 09:25 PM
B2FiNiTY's Avatar
Default Re: Are theses NGK spark plugs good for the R? (Mr.Integra)
Stock is denso...
Old Jan 13, 2003 | 11:54 PM
HYREV2NR's Avatar
Can't believe I'm editing a 7+ year old post but all the NGK stock #'s have since changed. On stock ECU I'd only go one range cooler than stock. Last I checked I believe it was a BKR7E-11.
Old Jan 14, 2003 | 10:51 PM
Mr.Integra's Avatar
sorry..
i meant their iridiums
Old Jan 14, 2003 | 10:56 PM
B2FiNiTY's Avatar
What is the part number on the Denso Iridiums?
Old Jan 15, 2003 | 11:13 PM
Mr.Integra's Avatar
i'm using IK20
and the stock number is 5304
[Modified by Mr.Integra, 12:15 AM 1/16/2003]
Old Jan 15, 2003 | 11:14 PM
B2FiNiTY's Avatar
What heat range is that?
Old Jan 15, 2003 | 11:15 PM
Mr.Integra's Avatar
http://www.densoiridium.com/identifyplugs.htm
Old Jan 15, 2003 | 11:47 PM
spoon_ek9's Avatar
denso heat range / 3 = NGK heat range
so 20 /3 = 6 . something, its equal to heat range 6 for NGK which is stock range for itr.
Old Aug 16, 2010 | 07:46 AM
elmagotomcat's Avatar
JDM ITR: NGK PFR7G-11 or DENSO PK22PR-L11
These are recommended by Honda.
Old Aug 16, 2010 | 08:00 AM
srt4mike's Avatar
Old Aug 16, 2010 | 11:46 AM
HYREV2NR's Avatar
Funny Mike LOL!
janiscrulzz
12
Jan 10, 2012 12:14 AM
TypeRuz
Oct 7, 2003 05:25 AM
BlendedEJ8
14
Mar 14, 2003 07:41 AM
BlackAC99
Oct 11, 2002 02:24 PM
Ubermensch
Jul 1, 2001 09:13 AM
