coilover question
Old Jan 9, 2003 | 08:32 PM
88turdbucket's Avatar
Default coilover question
i have an 88 crxsi and i have kybgr2 struts and apc65100 coilover sleeves and i want to know why every time i hit a bump my front struts and coilovers feel like they are smacking the hood of my car and i need t know if i need to adjust them up or do something else..... yes i know apc sucks thanks for your help
Old Jan 9, 2003 | 09:09 PM
91_hatch_si's Avatar
Default Re: coilover question (88turdbucket)
its a bump, what do u expect
Old Jan 9, 2003 | 09:14 PM
DohcRex's Avatar
Default Re: coilover question (91_hatch_si)
You just have to get used to it, i feel your pain.. as well as all other EF owners.
Old Jan 10, 2003 | 01:31 AM
travis's Avatar
If they're coilovers, raise them up all the way and see if the problem goes away.
Old Jan 10, 2003 | 07:27 AM
REDBARON's Avatar
Default Re: coilover question (travis)
You have it lowered to low. The Kyb Gr-2 shocks are good, but not that good. They are for about a 1-1.5" drop. After that the coilovers are going to overpower the shocks.
Do you have bumpstops? Did you cut the bumpstops halfway?
Old Jan 10, 2003 | 10:08 AM
Ef Whore's Avatar
Default Re: coilover question (REDBARON)
u said it yourself, u have apc---get them the **** out quickly---I am running sprint 3.5 inch springs on illuminas and my car makes no noises or sloppy bounces---I also left in the full bumpstop plus 1 upper strut bushing underneath that to absorb harshness---it works----there are tricks to tuning a slammed car but it will never work with apc's
Old Jan 11, 2003 | 05:34 PM
travis's Avatar
Default Re: coilover question (Ef *****)
APC just make the spring and C/O, right? That won't effect the damper's ability to control the spring so it's still a damper issue. In this case, it just sounds too low and something (either the damper or the bumpstop) is bottoming out. Raise them up, drive it, and if the problem goes away you can decide what to do next.
[Modified by travis, 7:34 PM 1/11/2003]
1tz @ h0nd@ th@ng
Suspension & Brakes
Jun 25, 2006 10:17 PM
Rob.
Suspension & Brakes
15
Jan 19, 2006 09:10 PM
tsjeff
12
Sep 24, 2003 12:49 PM
civteg1
Oct 14, 2002 04:57 PM
Knight2000
Sep 27, 2002 03:40 PM
