gen3 spec info NEEDED!! HELP!!!
Old Jan 9, 2003 | 07:49 PM
ahmelo's Avatar
Default gen3 spec info NEEDED!! HELP!!!
Hey guys, I just bought a 1990 Prelude Si and I was wondering if anyone
knew any stock specifications on it at all beside the 2.0L engine. I've been searching the internet forever to no avail. Anyone? Thanks!
- A
Old Jan 15, 2003 | 12:26 PM
madlude's Avatar
Default Re: gen3 spec info NEEDED!! HELP!!! (ahmelo)
if it's a 90 Si it has the b21a1 motor (2056cc) w/ 142 hp & 138 ft/lb...I have a 91 Si w/ this motor...it is the same block as the 2.0Si (1956cc, b20a5) but has thinner sleeves for the extra displacement. How much oil does yours burn?
Old Jan 15, 2003 | 06:39 PM
hatchblack's Avatar
Default Re: gen3 spec info NEEDED!! HELP!!! (madlude)
your info is a little off. the 90-91 preludes came with either a 2.0 or a 2.1. the 2.0 has 135 hp and 125 tq. the 2.1 has 140 hp and 135 tq. the 2.0 that you say is in there has an 81mm bore, 9.0:1 compression ratio, and puts down 105 hp and 109 tq to the ground on a dyno. the blocks are different in the bore size and sleeve material. the 2.0 has stronger walls made out of cast iron i believe. the 2.1 does not. the 2.1 puts 109 hp and 114 tq to the ground, 83 mm bore, and runs at 9.4:1 compression ratio. are there any other specs you would like to know about your 90 si? oh, and if you want to stop your b21 from burning oil, do what i did and put some lucas oil treatment into it. i went through a quart of oil every two weeks, then i added some of that and now i have gone about 3 months without adding any oil.
[Modified by 90crxlude, 3:41 AM 1/16/2003]
Old Jan 16, 2003 | 03:34 AM
ryanstev's Avatar
Default Re: gen3 spec info NEEDED!! HELP!!! (90crxlude)
Here's a list of specs for the USDM Honda Prelude on my site.
http://www.kaitaia.com/mycar/prelude.html
EDIT: Here are some specs for the JDM version:
http://www.kaitaia.com/mycar/prelude2.html
[Modified by ryanstev, 12:37 PM 1/16/2003]
POE
Apr 23, 2009 07:43 PM
allnaturalb16
Oct 12, 2006 11:04 AM
turfer
Oct 20, 2003 10:55 PM
Arthur
Oct 6, 2003 09:08 PM
ArmyGuard18
Apr 25, 2003 07:28 AM
