Question about steering problem...need insight..
Old Jan 9, 2003 | 07:24 PM
steveo97civic's Avatar
Default Question about steering problem...need insight..
alright, i have a 97 civic dx coupe..and in a snowstorm a month ago i wrecked the front end...3k bucks worth of damage later, i have my car fixed....but now that ive been driving for a week ive noticed some problems. The car is not tracking perfectly straight, but more importantly, i can feel some "play" or looseness in the steering of the car, almost like the front wheels or back are doing their own thing moving a little bit back and forth. I have to wait some time before the shop can get it in to fix, so i want to figure out what is wrong, because if its a balljoint or somthing i can fix myself...waht do you guys think it could be??? any tips or ways to troubleshoot this problem.. could it be the rear, because their is a creak sound when i push on the rear passenger side of the car...maybe a bushing is bad? idk....any tips or insight appreciated greatly, because then i can get the car on my buddies lift and look for the problem.... .....thanx.
Old Jan 10, 2003 | 06:29 AM
Default Re: Question about steering problem...need insight.. (steveo97civic)
up, need insight please..........!!
Old Jan 10, 2003 | 06:31 AM
Spade's Avatar
Does it just drift to one side when holding the wheel strait or sway?
Old Jan 10, 2003 | 10:47 PM
Default Re: Question about steering problem...need insight.. (Spade)
it seems to go left or right, there is alot of "play" in the steering, balljoint maybe, what could this be??
how do i troubleshoot it whn i jack it up?
thanks for help. steve
Old Jan 11, 2003 | 09:23 PM
anyone...?
up..........................
Old Jan 11, 2003 | 09:45 PM
racecarpete's Avatar
did the shop do an alignment?
Old Jan 11, 2003 | 10:05 PM
tominos's Avatar
Default Re: Question about steering problem...need insight.. (SilverCivic2k)
check the alignment. the steering wheel being too loose, could be the tie rods done for, or u need bushings. could be alot of things. what exactly does it do. can you explain it more? did the shop replace everything with new parts? and line up the frame?
Old Jan 12, 2003 | 04:11 PM
Default Re: Question about steering problem...need insight.. (tominos)
the was never bent, a full alinement was done too, the steering wheel feels slightly looser(more play) than it should have, but im not sure, it has a very slight wobble feeling as i go faster , and it seems to react slow to turning, the car almost pulls itself a little left or right, when i am driving, very slight tho.....how can i look for the prob, should i lift it and move wheels, and look at bushings and tie rods.....thanks for help.
xxjasonxx
Dec 8, 2008 11:48 AM
pd0019
Honda Civic (2001 - 2005)
Oct 5, 2008 11:30 PM
bmoua
Aug 20, 2007 01:46 PM
Elmo1968
21
Jul 27, 2006 07:19 PM
RiCE On IcE 2
Dec 20, 2002 12:43 PM
