Need some help guys...VAFC probaly on my SOHC VTEC...
Old Jan 9, 2003 | 06:47 PM
hwoody77's Avatar
Default Need some help guys...VAFC probaly on my SOHC VTEC...
Ok, so here's the deal guys. I recently installed my V-AFC, I had the same check engine light like everyone else.
For about 2 weeks, I kept disconnecting the battery in order to have the Check Engine light go away because of the V-AFC.
But here's the problem, recently my car began to stutter, like I'll be driving, and the car will die at low RPMs, I tyr to restart it and the car dies. The car would also stutter when I let go of the gas.
Then my friend began pulling the O2 sensor on the intake, and it went away. So what do you think happened? How can I fix this? An 02 simulator? Maybe I reset the ECU too many times, and it's not used to all this air?
Old Jan 10, 2003 | 04:58 AM
Noe Kozz's Avatar
Default Re: Need some help guys...VAFC probaly on my SOHC VTEC... (hwoody77)
Do you have any engine work done to the car? I think you've reset your ecu too many times also. Unless you have work done to the engine, it's really no point in getting a V-AFC.
96gsrlmo
Apr 15, 2004 05:37 PM
sagron69
11
Mar 19, 2004 06:51 PM
brian2903
Dec 11, 2003 06:25 PM
brian2903
Dec 11, 2003 06:24 PM
vteckiller
Jul 8, 2002 10:24 AM
