Will HX rims clear my 93 hb rear disc set up???
Old Jan 9, 2003 | 06:00 PM
hardboiled egz's Avatar
Default Will HX rims clear my 93 hb rear disc set up???
let me know thanks....
Old Jan 9, 2003 | 06:02 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Will HX rims clear my 93 hb rear disc set up??? (hardboiled egz)
um, I'm assuming you have an Si, and yes
Edit- why would you be worried about the rear when the fronts are bigger?
[Modified by Emerica, 7:02 PM 1/9/2003]
Old Jan 9, 2003 | 06:03 PM
Default Re: Will HX rims clear my 93 hb rear disc set up??? (Emerica)
thank you sir for you
just wonderin???
Old Jan 9, 2003 | 06:05 PM
Evs-One's Avatar
Solbros Owns Me
VX rims will fit your stock brakes too, unless you have ABS, 13 inchers
Old Jan 9, 2003 | 06:29 PM
qcoffey's Avatar
HX rims fit on my '99 Si.
Old Jan 9, 2003 | 07:38 PM
blykins's Avatar
Banned
Default Re: Will HX rims clear my 93 hb rear disc set up??? (qcoffey)
HX rims will not clear 94+ Si front brakes. I have them and i have washers to space the wheels out a little. Tomorrow i am going to file down the caliper so that i dont need the washers. I feel unsafe w/ washers b/t my wheels and brakes, if the washers fail, its game over when that wheel seizes.
Old Jan 11, 2003 | 05:32 PM
Default Re: Will HX rims clear my 93 hb rear disc set up??? (blykins)
.....so the brake disc diameter on 94 and up civics are bigger then 92-93 civics? hmmmm....good luck on modding it, bro.....be careful.
Old Jan 11, 2003 | 07:01 PM
ace1875's Avatar
First off sir this is not enough info are you ruming a GSR Disc setup or an SI Setup?
If you are runing a GSR you need 15 and over
Old Jan 12, 2003 | 07:08 AM
blykins's Avatar
Banned
Default Re: Will HX rims clear my 93 hb rear disc set up??? (ace1875)
I shaved the calipers a little, it was only like a millimeter. The washers were really making the wheel wobble ALOT. Now its as smooth as glass and i can finally get on it. Lightweight 14" HX wheels w/ azenis are awesome!! I think they handle better than my 15" 94/95 GSR's w/ azenis.
Old Jan 12, 2003 | 07:12 AM
rainmanEK's Avatar
big strong guy
Gsr back brake size is the same as 99-00 Si rear brake size!
Very little shaving needs to be done to clear 99-00 si and Gsr brakes up front!
I have done it too much times, I KNOW WHAT IM TALKING ABOUT!
eric
slowmovingegg
Oct 3, 2006 11:54 AM
B!^A@
Jul 30, 2006 03:22 AM
GReddy SI
11
Apr 14, 2003 07:19 AM
airon
May 10, 2002 09:37 PM
Black R
Apr 3, 2002 02:04 PM
