what about 215/45/17???
Old Jan 9, 2003 | 04:39 PM
sslude's Avatar
Default what about 215/45/17???
how would that size look on a 5th generation lude? would it be sticking out? if you dont think that size is good, can you give me pics (of a 5th gen) that would look good?
Old Jan 9, 2003 | 04:44 PM
sslude's Avatar
Default Re: what about 215/45/17??? (sslude)
or i mean, 225/40/17
Old Jan 9, 2003 | 04:46 PM
sslude's Avatar
okay, i got confused. you guys can close this thread. i foudn out that this is not what i was suppose to ask, and i foudn the right answer.
Old Jan 9, 2003 | 04:52 PM
Boostless97Lude
Guest
Posts: n/a
look at the pics of my car, i have 215/40ZR17 and the height is pretty much stock, i have it dropped maybe 1/4" if that. with that size on stock height, looks pretty good
Old Jan 9, 2003 | 07:42 PM
DsITR's Avatar
Default Re: what about 215/45/17??? (Boosted97Lude)
225/40/17 are taller overall than what Sam listed 215/40/17. (sams tire is properly plus sized, so it is almost identical in height as stock)
the x/40/y means 40% of x..so 40%of 225 is taller than 40%of 215.
running 225 vs 215 would increase your overall diameter, therefore gearing your car higher and reducing acceleration. The only advantage would be 225 is a wider tire, which may provide better traction.
unless you are putting down serious power, I wouldn't recommend 225's it will slow your car down noticeably. w/ 225's you would also be more likely to run into rubbing issues.
I Have some 215/40/17 spec II paradas for sale, $300..check my sig.
[Modified by dsludefosho, 9:43 PM 1/9/2003]
Old Jan 10, 2003 | 01:56 AM
Toda Built's Avatar
215/40ZR17 with a 1.5 inch drop ( i think they look pretty good)
(sorry pics are so big)
el_Presidente
Dec 18, 2006 08:10 PM
classified
Feb 3, 2006 07:48 PM
1NasteeEp
Apr 10, 2004 08:13 AM
hOndafienD 04
Jan 18, 2004 08:57 AM
lodown414
Nov 4, 2002 10:11 PM
