Which Carbon Fiber hood?
Old Jan 9, 2003 | 03:22 PM
RDLIN-IT's Avatar
Default Which Carbon Fiber hood?
Been looking into getting a CF hood and I know that Fiber Images and VIS both make quality hoods but is one preferred over the other. I did a search but did't come up with this answer. Thanks
Old Jan 9, 2003 | 03:23 PM
B2FiNiTY's Avatar
Default Re: Which Carbon Fiber hood? (RDLIN-IT)
Search by user:
"itrsport.com"
Old Jan 9, 2003 | 03:24 PM
ChapR
Guest
Posts: n/a
Too bad your not in So CAl. I got a fiber images hood with a 1inch defect in the resin. Its perfect otherwise. Rolled edges, perfect weave, even has the rubber weather seal in the front.
Old Jan 10, 2003 | 12:48 AM
PoW3l2BaN's Avatar
Both hoods are totally different from each other. And you decision depends on what you want the hood for. If you want a nice weight reduction, the Fiber Images hood only weighs about 12 lbs because its made with only a single layer of carbon fiber and has its skeleton doesnt weigh that much either. These hoods last a darn good time as you can see from their website. On the other hand, VIS hoods (I believe) are made for show purposes only, Their fitment is 99% perfect with 99% perfect weaves, but the downside is its weight. I think i read somewhere that VIS hoods are triple layered and its final weight is just about that of the stock hood, somewhere around 25+ lbs. Why does VIS use 3 layers to make a hood when 1 layer is enough. Remember, carbon fiber is a really really strong material. I chose the FI hood for weight reduction purposes and its reliability.
Old Jan 10, 2003 | 01:11 AM
iH8RICERZ's Avatar
i've never heard anything bad about fiber images......i actually used to sell their hoods because a guy i used to work for was a distributor or knew some one inside to get great deals. These hoods are sweet! If you watch their video that they have on their site, the stand on top of a latter and drop a 17" wheel w/ tire right in the center of the hood! No cracks, No scratches......i was in AHHH when i saw that!
Old Jan 10, 2003 | 01:41 AM
Type R's Avatar
Default Re: Which Carbon Fiber hood? (ChapR)
edit: messed up
[Modified by Type R, 2:44 AM 1/10/2003]
civicsracer
Oct 18, 2006 05:30 PM
dezznuttz
24
Dec 2, 2003 10:44 PM
stricker
May 13, 2002 09:56 AM
1320Motorsports
Oct 24, 2001 02:41 PM
solorex
Oct 23, 2001 06:43 AM
