B16A OBDII -- into a OBD I car. Tech question.
Old Jan 9, 2003 | 03:10 PM
IdotheSHOCKER's Avatar
Default B16A OBDII -- into a OBD I car. Tech question.
So I know the ECU is different, but what else has to be changed?
-- The distributor and ??
Thanks.
Old Jan 9, 2003 | 03:41 PM
pkek's Avatar
Default Re: B16A OBDII -- into a OBD I car. Tech question. (EGB18hatch)
wiring harness, yeah mostly the distributor wires and some other ****....do a search mehngg
Old Jan 9, 2003 | 07:08 PM
chad's Avatar
Moderator
first.....
don't use the obd2 ecu....get a chipped p28
either use obd 2 injector clips and splice into exsisting wire harness
or
find obd1 injectors (i have a set if you are interest)
get obd1 del slow vtec distributor....
don't worry bout hooking up the crank angle sensor...
you'll have to get an obd1 alternator
use your obd1 wireharness....
jdmjin
Nov 26, 2017 08:59 PM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
o5mar1
Aug 8, 2006 06:22 PM
revlimitcrx
Apr 2, 2006 12:29 PM
