heater/defrost buttons/lights not working
Old Jan 9, 2003 | 12:59 PM
James's Avatar
Default heater/defrost buttons/lights not working
I have 88 accord LXi and the buttons and lights on heat/defrost/vent/defrost&heat section are not working but the fan switches and fresh/recurculator buttons and lights are working. Split personality, huh. It stays at vent mode.
Any suggestions on what I can look into?
Thanks-
Jim
Old Jan 9, 2003 | 01:29 PM
YeuEmMaiMai's Avatar
Default Re: heater/defrost buttons/lights not working (James)
check fuse and connector
Old Jan 9, 2003 | 01:30 PM
James's Avatar
Default Re: heater/defrost buttons/lights not working (YeuEmMaiMai)
would fuse be under the dashboard next to steering wheel?
Old Jan 9, 2003 | 02:00 PM
preluder's Avatar
the one near the kick pannel in the drivers side under the dash. just check em all or the bug fuse holder . i think its a 7.5 fuse?
Old Jan 9, 2003 | 09:10 PM
cyrixvsp2's Avatar
Default Re: heater/defrost buttons/lights not working (preluder)
then if all the fuses are good, take out the controls, and test for current going to thoes bulbs. if it's what i'm thinking, the little green lights that light up when you push the button, those are leds.
if you are talking about the backlight, those are small 74 style bulbs and could have burnt out if you are getting current.
Old Jan 9, 2003 | 09:26 PM
89_LXi's Avatar
Default Re: heater/defrost buttons/lights not working (cyrixvsp2)
The LED's not working is a real common thing on 3rd gens as they are aging (and it's usually the same buttons). What happens is the soliders for the LED's develop cracks and no longer form a good connection. If you're good with a solidering iron you can take the printed circuit board out and re-solider them, and if done right they'll work like new. Otherwise, it could be something else inside. Is it the original buttons or a replacement? Because the inside wiring for 86-87 were different from 88-89, and were not interchangable.
Old Jan 9, 2003 | 09:30 PM
89_LXi's Avatar
Default Re: heater/defrost buttons/lights not working (89_LXi)
Oops....I need to read a little better, lol. Yea if none of them are working on that one side and it won't change modes, I'd check the connector and make sure it didn't come partially unplugged or something (after checking all fuses of course, under dash and under hood) Often times they put multiple things on 1 fuse, so be sure and check them all real carefully even if they don't seem relevant.
Old Jan 10, 2003 | 04:06 AM
James's Avatar
Hi all, Thanks!
Jim
sweatyjack
Sep 11, 2013 06:10 AM
cor4ey
Apr 16, 2010 03:53 AM
95silverteg
Sep 30, 2008 04:48 AM
gsrcivic619
Mar 23, 2006 10:53 AM
dpine
Jan 1, 2004 05:19 AM
