spark plugs
Old Jan 8, 2003 | 09:58 PM
2k1 GSR's Avatar
Default spark plugs
how often do u change your spark plugs? mine are still the same that it came with from the factory. and what spark plugs are you guys running? and how much did it cost. TIA
Old Jan 8, 2003 | 10:02 PM
Goldfingiz's Avatar
Default Re: spark plugs (2k1 GSR)
I like to replace mine every few months, just because it's an easy and cheap thing to do (depending on which plugs you get). They range from $6-40 depending on what you get
Stock plugs (NGK) should run about $8.00.
Goldfingiz
Old Jan 8, 2003 | 10:07 PM
2k1 GSR's Avatar
Default Re: spark plugs (Goldfingiz)
i havent changed mine and my car has 26,000 miles on it...do u think i will see a change in performance with new plugs?
Old Jan 9, 2003 | 05:44 AM
BSQ's Avatar
BSQ
The GS-R comes with platinum plugs which are good for 60K miles; therefore, there would be no real benefit to change them at 26K miles.
Old Jan 9, 2003 | 06:29 AM
bri's Avatar
bri
Default Re: spark plugs (BSQ)
I use Bosch platinum's, only 8 bucks a set but I see significant erosion of the tip when I change them every 20k
Old Jan 9, 2003 | 07:13 AM
Eva01's Avatar
Default Re: spark plugs (bri)
Use the NKG platinums. About 55$ from Acura.
Old Jan 11, 2003 | 01:21 AM
C_Rock77's Avatar
Default Re: spark plugs (Eva01)
God, they RAPE you!! Does ANYONE know of a cheaper source for the NGK platinum plugs that they run in the GSR's?
What are your guys' opinions on the Denso Iridium plugs?
Old Jan 11, 2003 | 10:37 PM
TimoneX's Avatar
New User
Default Re: spark plugs (C_Rock77)
They're hopelessly overpriced and do nothing to increase performance.
Old Jan 12, 2003 | 02:33 AM
97hb's Avatar
Ngk Copper every three months regardless of mileage. I do spray though and they are only $10 for 4.
lawrencelomanon
Honda CR-V & Element
Nov 15, 2017 10:37 AM
uLTrAvTEc757
Honda Civic (2006 - 2015)
Sep 5, 2006 05:27 PM
HX_Guy
Oct 23, 2001 08:19 PM
Babalouie
Jun 24, 2001 07:33 PM
