Just replaced my axles, now car vibrates after i turn... need new tranny bearings?
Old Jan 8, 2003 | 08:21 PM
Civiclx's Avatar
Default Just replaced my axles, now car vibrates after i turn... need new tranny bearings?
hey guys, thanks to your tips i was able to replace the axles in my 94 lx, however, it vibrates a little when i accelerate out of a turn, it doesnt click or vibrate during the turn like before (busted cv joints) however you can actually feel the car vibrate on the floorboard when i am going straight. Is this the axle just "settling" or is it something else like the tranny bearings? Got any tips?
Old Jan 8, 2003 | 08:47 PM
mantic6t9's Avatar
Default Re: Just replaced my axles, now car vibrates after i turn... need new tranny bearings? (Civiclx)
Are you sure you seated the axles all the way into the Diff, torqued the axle nuts down ect.......? They should not vibrate at all. Also make sure you torqued all your suspension bolts. All you should have removed were the pinch bolt, damper fork to LCA, and lower ball joint castle nut. Make sure you put the cotter pin back when reinstalling. Check it all out.
[Modified by mantic6t9, 11:48 PM 1/8/2003]
Old Jan 9, 2003 | 02:21 PM
all stock's Avatar
Default Re: Just replaced my axles, now car vibrates after i turn... need new tranny bearings? (mantic6t9)
balance ur wheels? when u go straight it vibrates? what mph?
AllmotorGSReg
Transmission & Drivetrain
May 16, 2010 09:21 PM
Jdm John
Dec 12, 2009 12:51 PM
ugpcrx
Sep 2, 2009 02:35 PM
Discontained
Oct 8, 2006 07:48 PM
SimplyTron
Dec 6, 2005 05:50 PM
