single wire 02 sensor to 4 wire...
i have a 94 cx hatch, has single wire 02 sensor. i have a d16z6 w/p28 which is setup for 4 wire 02 sensor. i have to use the engine harness from the cx... so how do i do that? i know i have to add wires for vtec, but do i need to chop the plug from my old harness off the crx and then run my own 02 sensor wires? thanks
it is easier and best to just get the d16z6 wire harness and do it that way.....have have done 3 1 to 4 wire conversions and eventually they all throw a tps code....becuase you splice into the green wire on the tps or map sensor
so do i need to have a hatch Si harness, or will a civic ex harness work as well? and how much do you think it will run me for a harness in good shape..?
also, with the z6 harness... will it all plug in just fine at the strut tower clips? and how do i add the wires from the strut tower to he ecu? thanka a lot
chrismanis
Nov 6, 2014 12:07 PM
