vtec head on 93 CX block what ECU will plug in and work?
Old Jan 8, 2003 | 07:11 PM
civicracer1993's Avatar
Default vtec head on 93 CX block what ECU will plug in and work?
if i use my stock harness and i run the wire for Vtec what ECU will plug in and work with a 95 SI head? an SI ECU or EX or what? what happens if i use my ECU ? also where does the Vtec hook up wires go ?
Old Jan 8, 2003 | 08:29 PM
Colton Grundy's Avatar
Default Re: vtec head on 93 CX block what ECU will plug in and work? (civicracer1993)
you need too use a p28 ans just wire one vtec wire
i got a p28 4 sale if you want it
Old Jan 8, 2003 | 08:31 PM
Default Re: vtec head on 93 CX block what ECU will plug in and work? (derrickcxhatch)
and you need too wire a 4 wire o2 sinser(sp)
you would be better off looking for a d16z6 if you ask import shops thay sell for really cheap $300-$700 is the going price
Old Jan 8, 2003 | 08:39 PM
ace1875's Avatar
Or if you don't wanna go through with all that get u a MSD RPM Activator Switch. Thats what i did and works fine my VTEC kicks in a 4800RPMs CRX-T did the wiring for me.
So you might wanna Im him
And you need a VTEC-E (1.5 VX) Timing Belt since the d15s are shorter then the D16
[Modified by ace1875, 5:41 AM 1/9/2003]
Old Jan 8, 2003 | 09:11 PM
chad's Avatar
Moderator
Default Re: vtec head on 93 CX block what ECU will plug in and work? (ace1875)
don't do that swap.....that's just plain stupid!!!!!!!
ilovemyb16a
May 18, 2006 12:58 PM
shbrown
Aug 11, 2005 04:51 PM
sethm
Dec 7, 2003 08:57 PM
stangkilla
Dec 12, 2001 08:02 AM
