More help with spring install please
Old Jan 8, 2003 | 03:48 PM
1EuroEp's Avatar
Default More help with spring install please
Awww, this sux. So i got the tie rod off the strut no problem, put the spring on but no I cannot replace the upper of the two large bolts back in to connect the strut and brake set up. The brake just sits at a 45 degree angle and wont budge. Have tried everything i and three other people could think of an im very frustrated...anyone?
Old Jan 8, 2003 | 05:43 PM
ep3's Avatar
ep3
Default Re: More help with spring install please (1EuroEp)
i think your axle popped out. try popping it back in.
Old Jan 8, 2003 | 05:48 PM
1EuroEp's Avatar
Default Re: More help with spring install please (ep3)
Yeah thats what someone just suggested on another site too. So my driveshaft has come out and there are three bearings that need to line up? I will have to wait for sunup to check it out though. Can I peel back the rubber boot or is it better to line them up by touch? Thanx!
David
Old Jan 8, 2003 | 05:51 PM
ep3's Avatar
ep3
i just messed around with it and it popped back in. if the other site you were talking about was ephatch.com, do a search in the suspension section. i think someone drew a diagram.
[Modified by ep3, 2:52 AM 1/9/2003]
Old Jan 8, 2003 | 06:14 PM
the JigGa mAn's Avatar
POST PICS WHEN DONE.....
can i see your pics, if you have any?
Old Jan 8, 2003 | 09:17 PM
1EuroEp's Avatar
Default Re: More help with spring install please (the JigGa mAn)
Yeah I just played with it a bit, turned it counter clock wise then back a little and it slid right in. So I finished the front tonight and will get on the rear tomorrow. I couldnt believe how easy it was
But thanx all for your help, it's much appreciated
David
Old Jan 8, 2003 | 09:54 PM
TheRoxorcist's Avatar
dave. i'll take pics for you tomorrow
Old Jan 10, 2003 | 02:55 PM
CHILIBEANZ's Avatar
if you have to do the fronts again,( which you probably will) use a seperate jack for the brake rotor. by raising it it's easier to line up. once you have the at least one of the holes semi-lined up you can use a screw driver and put it into the hole before the bolt in order to line it up. (it helps with leverage) hope this makes sense. now time for the
G0tSchnitzel?
13
Mar 6, 2010 10:50 PM
BIGDSTG
Honda S2000
14
Dec 17, 2008 05:35 PM
bb4ninja
Mar 6, 2006 09:03 AM
KOREAN
Aug 13, 2005 12:55 PM
1EuroEp
Jan 8, 2003 12:54 PM
