brake failure
Old Jan 8, 2003 | 01:48 PM
eg_92vxhb's Avatar
Default brake failure
Hello,
I am having serious brake issues....i cant get any pedal pressure....i have completely replaced the booster and master cylinder....yes...everything has been bled out properly...i was wondering if it could be a vaccum problem or something to that extent.
THIS IS THE SYMPTOMS!!
When i depress the pedal i get nothing...if you constantly jabb it gains some pressure but, when you let go it goes back to nothing...im lost please help im about to go nuts!
Old Jan 8, 2003 | 01:49 PM
silverEH2's Avatar
Default Re: brake failure (eg_92vxhb)
that sux, someone help this guy
Old Jan 8, 2003 | 02:58 PM
JpiZz0's Avatar
Default Re: brake failure (silverEG6)
check all ur brakelines for holes look under the car for an leaks? when u bled the brakes, did u go start from the caliper farthest from the master cylinder? u should have pressure if not are u using the right fluid? that makes a difference find out if its dot 3 or 5 good luck
jp
spender1326
Apr 6, 2004 03:28 PM
95GS-R
Jul 18, 2003 08:15 PM
eg_92vxhb
Nov 14, 2002 10:05 PM
Angry Joe
Jul 24, 2002 05:17 AM
CD8
Jun 18, 2002 09:30 AM
