My trunk rattles...any way I can tighten it?
Old Jan 8, 2003 | 11:02 AM
96 SOHC VTEC's Avatar
Default My trunk rattles...any way I can tighten it?
I noticed that my trunk vibrates up and down when I am driving, as if it weren't closed all the way. Is there any way I can tighten the mechanism that holds it in place so it won't move at all?
Old Jan 8, 2003 | 11:23 AM
EK MONEY's Avatar
Default Re: My trunk rattles...any way I can tighten it? (96 SOHC VTEC)
check to make sure the latch is still good. With the trunk down, get in the trunk and try and find things that are rattling, u can use a rubber mallet and lightly tap here and there to find it. Underneath your speakers that are bars that travel back and fourth that stabalize the trunk when lifted. watch out for those buggers, there loud.
Old Jan 8, 2003 | 11:41 AM
krazy's Avatar
Default Re: My trunk rattles...any way I can tighten it? (Peagreenhatch)
if its anything like my trunk, there should be some rubber stopper things on the underside of the trunk. unscrew these a bit so when u close it, it pushes into the trunk more. this should help a lil.
krazy
Old Jan 8, 2003 | 12:40 PM
chad's Avatar
Moderator
TURN THE bass down
Old Jan 8, 2003 | 12:43 PM
-Whitey-'s Avatar
Default Re: My trunk rattles...any way I can tighten it? (chad)
adjust the strikers so it closes tighter
Old Jan 8, 2003 | 12:49 PM
Default Re: My trunk rattles...any way I can tighten it? (one-syk)
Thanks guys.
Old Jan 8, 2003 | 02:01 PM
euclid's Avatar
under the 94 coupe trunk latch there is a small spacer... take the spacer out and the trunk will have to close tighter to properly latch.
Rest0014
Honda Civic (2001 - 2005)
Aug 8, 2009 08:32 AM
cats_on_ice
Jul 14, 2006 10:11 PM
Jlamar757
Jun 15, 2006 01:03 AM
00ekcoupe
Mar 6, 2006 06:39 PM
