Air bag and SRS unit removal question
Old Jan 8, 2003 | 10:24 AM
Cynical 1's Avatar
Default Air bag and SRS unit removal question
OK. I am in the process of gutting my car to redo a little of the interior.
I want to remove the steering wheel/airbag in a few weeks to make room for a new steering wheel (probably a Mugen). I have unhooked the wiring harness and put the red short pin in.
Will it be ok to drive around like this after:
I also want to remove the SRS control unit, found under the heater box. If I remove this unit, will I constantly ahve a "SRS" light on in the dash. And if so, any tips on how to get rid of it? (hopefully nothing like "remove the bulb")
Let me know!
Old Jan 8, 2003 | 10:35 AM
Simple's Avatar
Default Re: Air bag and SRS unit removal question (Revolveu2)
the beauty of my honda was... i could drive around with nothing wired up right, or even at all... You can still drive where ever you want... as far as the SRS light is concerned, either do what you said.. and take out the bulb... or just unplug the harness into the SRS slot on the gauge cluster... mine was constantly on so i just unplugged it from the cluster... and no problems
Old Jan 8, 2003 | 10:38 AM
ejprimo's Avatar
Default Re: Air bag and SRS unit removal question (Simple)
when i took out the srs control unit, the light disappeared.
Old Jan 8, 2003 | 10:40 AM
Cynical 1's Avatar
Default Re: Air bag and SRS unit removal question (ejprimo)
Cool.
Thanks guys. I was just worried it would freak out the ECU too...
lsjon
Jun 17, 2009 02:11 PM
saywhat
23
Jan 28, 2007 08:28 AM
cdfive.
Apr 25, 2005 05:57 PM
EK45VTi
Jan 11, 2005 01:11 PM
