Honda S2000 Honda S2000
Tires??
Old Jan 8, 2003 | 09:41 AM
cw98typer's Avatar
Default Tires??
My mom has an 01" s2k and needs new tires but doesn't need $230 a piece tires(potebza s-02), is anybody on here going with a different set up? If so how much and do u like em?
Old Jan 8, 2003 | 09:48 AM
SECRET AP1's Avatar
Default Re: Tires?? (cw98typer)
a word of advice about tire sizing: although normally you would simply consider buying tires of another brand or model using the same tire sizing as from the factory, you should know that the Potenza S02 models that come with S2000s are specialized models made for Honda only. if you go out and buy another set of S02s without asking for the Honda S2000 model, then you will notice that they are more narrow.
in short:
- if you choose to buy S02s again, make sure you specify that they get the S02 Honda S2000 model (there are Porsche and BMW models as well). you can stick to the OEM sizing if they do get the right model.
- if you go with any other tire, you will need 225/45 in front and 245/45 in the back.
good luck
Old Jan 8, 2003 | 10:36 AM
blacks2000's Avatar
Default Re: Tires?? (SECRET AP1)
I have toyo proxes. Love the handling, but they prolly cost about the same as the SO-2. It depends on what conditions the car will be driven in. If she wants an inexpensive tire, try Kuhmo's. I had them on my teg and they were good for the money. Check http://www.tirerack.com
Old Jan 8, 2003 | 11:36 AM
cw98typer's Avatar
Default Re: Tires?? (blacks2000)
Thanx for your help, much appreciated
Old Jan 9, 2003 | 08:55 PM
mcs2000si's Avatar
I have Bridgestone Potenza RE950's on my SI and love them! they handle well in the rain too. Check tirerack.com for prices on the size you need.
Old Jan 9, 2003 | 11:56 PM
SilverS's Avatar
Kumho 712's are good street tires and cheap to boot!
[Modified by SilverS, 11:02 PM 1/9/2003]
hamda
Jun 22, 2008 06:05 PM
soulrider4ever
Honda S2000
39
Mar 5, 2008 11:32 AM
al4t1gbundy
Sep 10, 2007 01:42 PM
Xx_AzN_FuRy_xX
Honda S2000
15
Jun 5, 2005 12:30 PM
