Rear sway bar install
Old Jan 8, 2003 | 08:24 AM
k.'s Avatar
k.
New User
Default Rear sway bar install
Can someone post up info on how to install a rear sway bar for a 99-00 Civic EX?
I have the bar, I know I need endlinks, etc. from an Si, I did a search but all I found was pictures of bars already installed. If anyone can post up parts (or part #'s from honda would be even better!) I would need for the install, which tools, and a quick how-to...I would be very very thankful.
~k.
Old Jan 8, 2003 | 10:10 AM
hatchdrvr's Avatar
Default Re: Rear sway bar install (k.)
try http://www.hondaautomotiveparts.com
Old Jan 8, 2003 | 10:16 AM
kommon_sense's Avatar
Default Re: Rear sway bar install (hatchdrvr)
Check the 'howto' section on http://www.hazone.com
http://www.hazone.com/hsirearsway.htm
[Modified by kommon_sense, 2:16 PM 1/8/2003]
Old Jan 8, 2003 | 02:02 PM
95excoupe's Avatar
Default Re: Rear sway bar install (kommon_sense)
I wouldnt even install it go for a bigger bar and youll be way way happier. ST 19mm is nice i have it on my car, cuts back on body roll alot.
Old Jan 8, 2003 | 02:41 PM
JoshuaVTEC's Avatar
Here is a how-to... http://www.jdmfan.com/technical/suspension/mugen_rsb/
Old Jan 8, 2003 | 08:37 PM
k.'s Avatar
k.
New User
Default Re: Rear sway bar install (95excoupe)
I bought a 17mm AEM bar. I think its suitable for my needs. Anyhow, that HAZONE how-to was the most helpful. Thanks!
~k.
Old Jan 8, 2003 | 08:42 PM
Daniel's Avatar
great site
Old Jan 8, 2003 | 09:08 PM
chad's Avatar
Moderator
jack the car up and go at it....just learn by trial and error....
Old Jan 8, 2003 | 09:20 PM
k.'s Avatar
k.
New User
Default Re: Rear sway bar install (chad)
i cant afford trial and error anymore.
~k.
Old Jan 9, 2003 | 01:28 AM
tFUnK's Avatar
im pretty sure u figured it out by now but it's really just about drilling new holes on the subframe (no need if using si brackets and bushings) to put on the brackets with the bar already through them and then attaching the endlinks onto the lca's then connecting the bar. depends on which endlinks you are using of course, and how the aem bar attaches to the endlinks. and then there's always the endlinks they sell at pepboys which are actually pretty good as well as bushings.
Old Jan 9, 2003 | 07:26 AM
k.'s Avatar
k.
New User
Default Re: Rear sway bar install (tFUnK)
I think I'm going to use the Si brackets if its cheaper than the stuff they sell at PepBoys. I want to avoid having to drill anything though.
~k.
Old Jan 9, 2003 | 09:20 AM
s73's Avatar
s73
New User
depends on which bar you are putting on........i also have a 6g civic......you don't need to drill a thing........the holes should be pre-drilled
Old Jan 9, 2003 | 10:36 AM
k.'s Avatar
k.
New User
Default Re: Rear sway bar install (s73)
Yeah i know the main holes should be predrilled. So hopefully it will be kinda "plug-n-play"
Thanks.
~k.
shahriar35
Nov 19, 2009 01:45 AM
Therapy
Jan 6, 2004 07:51 PM
sicivic
Dec 24, 2002 05:58 AM
Nighthawk GS-R
Apr 23, 2002 03:58 PM
swarsing
Nov 9, 2001 07:22 AM
