Cant take off Bolts
Old Jan 7, 2003 | 09:58 PM
Ronin Integra8's Avatar
Default Cant take off Bolts
I been trying to do my coilovers and shocks. This is my first time dealing with suspension, and overall it was a decent experience. Ran into many rusted bolts and stuff like that, that took forever to take off. Not to mention the nut on the top of the stock set up got striped, and then the hex part at the tip got striped also (had to drill that **** out).
So far I've finish the front. Now I'm working on the rears, but I cant get the two bolts on the bottem off, nor lose. I used a air compressed gun thing, that didnt work. Then I got a torque wrench(greatest tool invented) and broke so many sockets. I tryed WD 40 and liquid wrench. The bolts just wont budge. Does anyone have any clue on what I can do? Please help, cause my car looks like its slanted, low in front and high in rear
Old Jan 7, 2003 | 10:03 PM
Brasspremier's Avatar
Default Re: Cant take off Bolts (Ronin Integra8)
get stronger sockets... and... uh, get long *** pole, stick it in the end of the wrench, so its really long, giving it lotta torque
Old Jan 7, 2003 | 10:30 PM
tilt's Avatar
keep soaking the bolts. best thing to do is rig up a way so they literally bathe in the penetrant overnight. then go at it with a breaker bar and cheater bar.... those bolts are known to break so keep that in mind as well.
Old Jan 8, 2003 | 12:47 AM
216.226.142.95:27016's Avatar
Default Re: Cant take off Bolts (tilt)
try an impact wrench
Old Jan 8, 2003 | 01:05 AM
EKB18BPR3's Avatar
soak it in wd40 over nite. let that **** rust get eaten away
Old Jan 8, 2003 | 01:07 AM
dirtyazn's Avatar
Default Re: Cant take off Bolts (216.226.142.95:27016)
if your talking about the bolt that holds the shock to the lower arm try unbolting the other side i remeber when i did mine one side was welded and the other pointing towards the back wasn't
it just looks like a nut but its actually part of the shock itself
well to make a long story shot we broke it and bought a new nut and bolt
Old Jan 8, 2003 | 04:30 AM
Ricky Rojales's Avatar
Drill it out if you need to. It's sounds like the bolt is frozen permanently in the bushing... this isn't ucommon. Before you replace the bolt make sure you put a generous amount of anti-sieze compund to prevent this from happening again.
Old Jan 8, 2003 | 04:58 AM
cornbread's Avatar
I don't know what year your car is but that bolt one integras usually freeze up. I have seem then frize up on 00 tegs. It's going to brake no matter what so just drop by the dealer and get a new bolt.
Old Jan 8, 2003 | 05:57 AM
reno96teg's Avatar
Default Re: Cant take off Bolts (smokeee)
there was no way around it, i had to drill both of those out..
tjsker
Jul 25, 2006 11:21 AM
civiccoupe94
34
Nov 17, 2005 08:15 AM
notsure
Jun 18, 2004 10:57 PM
functionFiRst
Mar 2, 2002 10:44 AM
