Need help on rear disc conversion.....
Old Jan 7, 2003 | 09:39 PM
Boostin Ex's Avatar
Default Need help on rear disc conversion.....
Ive got a 98 civic ex turbo and im looking to go to rear disc brakes i just want stock disc (no big brakes). So what do I need to go to rear disc or does anybody on here sell them?
Thank for any info H/T.
Old Jan 7, 2003 | 10:20 PM
euclid's Avatar
Default Re: Need help on rear disc conversion..... (Boostin Ex)
run a search man, you could spend all night reading how many posts will come up.
Old Jan 7, 2003 | 10:45 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
This isn't for the 6gen, but I figure the only differences should be in the brake lines and e-brake cables, beyond that everything else should be straightforward.
Here:
http://tech.hybridgarage.com/tech/brakeswap.html
Old Jan 7, 2003 | 11:25 PM
Biglooney2's Avatar
Default Re: Need help on rear disc conversion..... (SHAUNTS99)
get some gsr or ls trailing arms and brake assembly some gsr,si,ls ebrake cables and some stainless lines for a gsr and your done.
Old Jan 7, 2003 | 11:30 PM
IM ALL BOB's Avatar
Default Re: Need help on rear disc conversion..... (Biglooney2)
for 6th gen you can run the stock civic trailing arm with the gsr/ls rear disc conversion or make it easy and locate a full SI rear disc conversion that includes the civic trailing arm and ebrakes cables... but u can use gsr/ls cables as well
dmetry
Honda Civic (2001 - 2005)
Nov 8, 2011 09:58 AM
Civic_86Hybrid
Jun 11, 2007 07:27 AM
98h22
Feb 9, 2006 04:44 PM
CHONCH
Aug 7, 2004 05:01 PM
Steak84SS
Jun 25, 2004 08:07 AM
