How do you guys clean your engine bays?
Old Jan 7, 2003 | 07:18 PM
Ideal's Avatar
Default How do you guys clean your engine bays?
The only really good cleaning stuff i have is simple green. But im willing to buy.
What should be covered up?
-Jon
I know this is probably a repost, but because there are alot of new people i thought some new ideas may be brought in.
[Modified by Ideal, 8:34 PM 1/7/2003]
Old Jan 7, 2003 | 07:36 PM
niedejb's Avatar
Default Re: How do you guys clean your engine bays? (accord_expert408)
Engine Bright.
Let sit.
Spray bottle with squirting pattern to rinse off. (keeps the water where you want it)
ratherbewalking's Avatar
COOL! lets everyone post in the wrong forums.
Old Jan 7, 2003 | 07:38 PM
Ideal's Avatar
Default Re: How do you guys clean your engine bays? (ratherbewalking)
actually throught the search function you can tell that they just arent put in the cosmetics forum, i see a few in the tech forums, civic forums, and i recal a very, very long time ago there was one in this forum.
Old Jan 7, 2003 | 07:39 PM
https://honda-tech.com/zerothread?id=365271 \
i did a search for you ! in the appearance forum. wasnt really that hard
Old Jan 7, 2003 | 07:56 PM
Ideal's Avatar
absolutely amazing you found a thread on cleaning engine bays, even though i just said that through searche i found a few in different topics on it BESIDES the appearance forum.
-Jon
[Modified by Ideal, 8:56 PM 1/7/2003]
Old Jan 7, 2003 | 09:42 PM
iam7head's Avatar
Default Re: How do you guys clean your engine bays? (Ideal)
actually been covered alot of time...
simply green works great..MTKommoder used it for his 240
Old Jan 7, 2003 | 10:13 PM
89_LXi's Avatar
Default Re: How do you guys clean your engine bays? (iam7head)
Simple Green kicks ***! I use that stuff for everything. A pressure washer helps alot too
Old Jan 7, 2003 | 10:15 PM
iam7head's Avatar
Default Re: How do you guys clean your engine bays? (89_LXi)
Just make sure do it one spot at a time..
dont flood the electronic part..
Old Jan 8, 2003 | 05:20 AM
Nick M's Avatar
pressure washers if the psi is too high will cause some damage, its easy to make a big mess out of an engine bay with a pressure washer if you arent careful
simple green is good, when I used to detail cars at Honda we had this stuff called C49, its a pink simple green-like cleaner that worked even better than simple green, stuff was amazing. If you can find it, buy it.
Old Jan 8, 2003 | 05:52 AM
Desslok's Avatar
Default Re: How do you guys clean your engine bays? (Nick M)
I like the Engine Detailer kit at Pep Boys. Comes with can of degreaser and can of detailer to condition hoses, rubber etc. My bay looks new.
RSMACHINES
Sep 27, 2008 05:28 AM
Coffee33
Mar 9, 2005 05:12 PM
AMG
18
Feb 21, 2003 05:58 AM
B18C5-EH2
42
Apr 7, 2002 05:39 AM
WuShu
16
Jan 29, 2002 04:12 AM
