ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary?
Old Jan 7, 2003 | 04:56 PM
IntEGNYC's Avatar
Default ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary?
Ive been dredging through the archives and there's been concerns about subframe tearing.
I wonder if its helpful to use a Rear Lower Tie bar in addition to the ITR RSB and BSQ kit.
Anyone with a similar upgrade kindly share their experience and comments.
Old Jan 7, 2003 | 05:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (IntEGNYC)
Well the ITR's have both, but their purposes are different. Sway bars controls body roll through corners, while the tie bar helps reduce subframe flexing.
Old Jan 7, 2003 | 10:38 PM
lshobo's Avatar
According to BSQ, subframe tearout only occurs when the sway bar has been mounted improperly. With the BSQ kit, it shouldn't be a problem at all.
A tie bar would greatly compliment the sway bar. I recommend Benen.
Old Jan 8, 2003 | 05:34 PM
IntEGNYC's Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (lshobo)
Benen !
Old Jan 8, 2003 | 06:46 PM
Tweakmeister's Avatar
I just sold my Benen bar.
It's an AWESOME piece, but when you are counting your pennies a Neuspeed will suffice
Old Jan 8, 2003 | 08:03 PM
speedevo's Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (Tweakmeister)
does the neuspeed require any extra modification? also if anyone knows does the comptech one require drilling?
Old Jan 8, 2003 | 08:10 PM
MachAF's Avatar
I read an article on a honda website, can't remember it. Anyway the guy said that a lower tie bar is necessary. I talked to Bret about it, he said that guy was wrong.
A lower tie bar is not necessay with a sway bar.
Old Jan 8, 2003 | 08:53 PM
:jdmshmaydm:'s Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (machaf)
Could you get an ITR lower tie bar to fit on a GS-R?
Old Jan 8, 2003 | 09:16 PM
mr_mbuna's Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (Gatecrasher18AF)
Its not about neccessary or unneccessary... as always with tuning our kind of cars its about value. Yes, it will definately help. Everything does. But how much benefit do you get for your money? I've heard not a lot. Money might be better spent elsewhere. However, I do have a Neuspeed rear lower tie bar. I can't speak as to the benefit it provides in my case considering I had about 5 suspension things installed at once, sorry.
Ben
Old Jan 8, 2003 | 11:34 PM
lshobo's Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (mr_mbuna)
true, lower tie bar is unnecessary, and it is also true that 'bang for the buck' is highly valued. when i say the tie bar would compliment the sway bar well, it's all about improving your car's rear end, and helping to tighten up on the turns. just try driving with the swaybar until you get 'used to it' - that is when you don't even say 'wow' to yourself anymore at the vast improvement in handling. then try the tie bar and you will appreciate its utility. personally, i have the benen with the itr sway and it kicks ***.
Old Jan 8, 2003 | 11:37 PM
lshobo's Avatar
forgot to add that with something as nice looking as the benen bar, it really adds something to the rear of the car aesthetically. the car looks more 'grounded,' almost eliminating the need for any sort of rear lip or valence treatment.
Old Jan 9, 2003 | 02:10 AM
ebelp's Avatar
If you look at this pic of the ITR subframe, it seems to be shaped differently than the GSR's. There's no flat mounting spot on the GSR as seen here:
Old Jan 9, 2003 | 03:27 AM
IntEGNYC's Avatar
Insightful.
A most excellent thread. thanks all
Old Jan 9, 2003 | 09:53 AM
tubedriver's Avatar
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (speedevo)
I have the Beaks kit/R swaybar with Neuspeed lower tie bar. Beaks sells longer bolts and spacers that allow the Neuspeed bar to mount without any difficulty. Did it make a difference. Well, in theory everything makes a difference but I made two changes at a time (swaybar and lower tie bar) so I can't say what mod did what. The car does handle better now.
Old Jan 9, 2003 | 06:32 PM
94integrals's Avatar
Theoretically the Comptech tie bar should be the most effective since it mimics the Type R stock reinforcement in the way it attaches to subframe. It's really hard to feel any difference after adding any sort of chassis reinforcement. It is just comforting to know that your car is a little more rigid
Old Jan 9, 2003 | 09:55 PM
Community Builder
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (94integrals)
Actually the Comptech sway/tie combo should be the most effective since the tie bar is a single solid piece of machined metal, and it provides the most chassis reinforcement and solid mounting points for the swaybar brackets out of any of the normally used methods (BSQ kit/Beaks kit/Comptech sway-tie combo).
Old Jan 10, 2003 | 01:42 AM
Default Re: ITR Rear Sway Bar with BSQ Kit... Lower Tie bar still necessary? (ebelp)
Whoa it does have those extra flat spots on the subframe. I didn't know that. Thanks.
Old Jan 10, 2003 | 09:41 AM
Windows 95's Avatar
You're concern seems to be whether or not a rear lower tie bar will help prevent an ITR rear sway ripping out of your subframe. I don't think that a rear lower tie bar will help reinforce your subframe in terms of keeping the ITR sway bar from ripping out. As for the difference in handling with the addition of a rear tie bar, the results will be minimal. All my friends w/ hondas that have invested in rear lower tie bars have reported very little, if any , difference in handling.. but it does look nice from behind A brand new ITR sway bar w/ all hardware will should run you under $90, +$20 for BSQ=$110, and a HUGE difference in handling. A rear lower tie bar, you're looking at at least that much, and for big name bars up to 2x that amount. For moneys sake, I would not bother with the tie bar unless you have extra cash just floating around
Old Jan 10, 2003 | 10:38 AM
OBDI JEDI's Avatar
from the looks of it, can you mount the benen bar with the comptech with the ITR rear sway bar!?!?!?
DC2 Mang
Suspension & Brakes
12
May 12, 2020 09:12 AM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
Takumi Fujiwara
Feb 22, 2005 06:50 PM
jeremy.
Dec 15, 2003 08:49 AM
Red98GSR
Jun 16, 2001 07:34 AM
