Taking out rear back seats from my EG
Old Jan 7, 2003 | 11:19 AM
Nocturnal's Avatar
Default Taking out rear back seats from my EG
How do I go about dismantling the seat assembly in the rear? Do I need to take out the panels in the back seat as well? I tried to take out the back seats but it seems as if it's stuck!
Old Jan 7, 2003 | 11:23 AM
s13_240sx_92's Avatar
Default Re: Taking out rear back seats from my EG (psychotic)
Try looking at the seats from the rear of the car. You'll see where they are bolted down. At least the butt part of the seat. The seat back you'll see the c-clips(?) I donno what they are called. But if your brain is functioning you'll be able to figure it out. Good luck
Old Jan 7, 2003 | 11:30 AM
Nocturnal's Avatar
Default Re: Taking out rear back seats from my EG (s13_240sx_92)
Should the seat require a lot of pulling and yanking? Cuz I tried yanking it out of the C clip and it still wouldn't budge.
Old Jan 7, 2003 | 11:40 AM
BROOD's Avatar
Bottom cushion: remove single bolt at rear side of cushion near center, pull the rear edge of the cushion up and towards the front (rotating so to speak) the clips will be released and the cushion can be removed.
Backrests: find the backrest pivots, remove the small black plastic clips, move on backrest to the side and angle it out of position. Take a look at it you will understand how it works.
Old Jan 7, 2003 | 11:42 AM
Nocturnal's Avatar
Default Re: Taking out rear back seats from my EG (SLPR)
Man this forum ******* owns me. Thanks so much. I can get so much help here in a matter of seconds. THIS ******* FORUM OWNS ME I SWEAR ON MY LIFE.
SOHCVTEC
Honda CR-V & Element
Mar 24, 2018 02:25 PM
SpecialRequest
Jan 8, 2016 06:29 AM
LoNgHoRn
Jan 18, 2007 01:31 AM
fenix77
Mar 28, 2004 10:39 PM
daniel89civ
Mar 13, 2002 05:11 PM
