ITR Transmission
I'd get the ITR trans because for the same price as a quaife + install, you can have a whole separate transaxle. You can either sell your old trans or keep it for backup.
How would a stock ITR transmission be better all-around than an Si transmission with a Quaife?
dunno.I can understand a 98spec JDM ITR tranny for the FD but then you'd have to swap the B16A 4th/5th gears in unless you wanted the weak 4th/5th.
Personally I'd do the Quaife and a JDM or ATS FD (assuming it fits in the casing, not too knowledgeable on Si trannies).
Eric: I know Del Sol DOHC VTEC trannies have the same ratios as the ITR tranny and *think* the Si one does as well. If not then I'd say get the ITR tranny with the factory LSD.. I'd rather have the ITR/DelSol B16A ratios and factory LSD then Quaife and GS-R or whathaveyou ratios..
Maybe they're referring to the gear ratios...
edit: On the topic of comparing different trannies, which would be better for drag? GSR or ITR? GSR tranny has a closer gear ratio between 2nd and 3rd as well as 3rd and 4th.
[Modified by StinkyTofu, 8:22 PM 1/7/2003]
They should look up the gear ratios between the trannies before speaking because one who has will find out that the Si and ITR have the same gear ratios.
) final drive and the factory LSD.
Anyone know the answer to my question? Thanks and i hope ya don't mind me asking questions in your thread
"On the topic of comparing different trannies, which would be better for drag? GSR or ITR? GSR tranny has a closer gear ratio between 2nd and 3rd as well as 3rd and 4th."
."On the topic of comparing different trannies, which would be better for drag? GSR or ITR? GSR tranny has a closer gear ratio between 2nd and 3rd as well as 3rd and 4th."
DON'T waste money on an ITR tranny!!!
All you need to have your VERY OWN ITR tranny (if you have the B16 tranny already) is:
JDM 4.78 Final Drive
JDM ITR/CTR LSD
Integra Type R shifter
And if you really want it to be like the 98 spec JDM ITR tranny, then get the 4th and 5th gears from a JDM ITR tranny..
One thing I'm not 100% sure about, is the syncros on the ITR tranny vs. B16. I've heard they are different... but I'm not sure.
Why spend the money on a USED ITR tranny that will probably grind 4 out of 5 gears? Keep your stock B16 tranny because you know what it's been through, and you know how it shifts. After you take it apart and put it back together with those components, it's going to be the same tranny, but better.
JDM ITR/CTR LSD
*shakes head*
the SI and ITR have the same gear ratio and it's closer than the GSR. It'll be better for drag racing. If you have turbo, go with the GSR tranny. It's longer but your power from the turbo will make it for it. The SI and ITR tranny have the same ratio but it has different components. The one's off the GSR and ITR are beefier.
Having closer ratios doesn't mean better for drag racing but in the situation with the integras, having the ITR ratios are good because it's pulls hard and you don't need to stay in third that long with the amount of power you have in your integra. You'll need to go into fourth in order to accelerate faster
apart from the obvious, the gears are of a different ratio...and the final drive/ring gear is smaller on the Si/SiR...
what else is different here?
stumpyf4
Nov 9, 2004 08:09 PM
Black R
Mar 5, 2003 08:08 PM
