I need to talk to everyone with a 4th gen 5spd that's running an h22 or h23.
What tranny are you using? For those of you running the lude tranny, what tranny mount did you use? The reason I'm asking this is because I don't see how to get the motor in and sitting straight without moving the tranny mount bracket on the frame.
I have 4th gen Accord running a prelude tranny. I rewelded the tranny mount bracket on mine to get it to fit right.
If the car had a 5 speed in it already, you will drill and tap the factory "bosses" on the Prelude tranny casing and relocate 2 of the studs. (this will allow you to use the Accord 5 speed mount)
[Modified by 2point6, 1:39 PM 1/7/2003]
Thank you very much. Mine 4th gen is 5spd already. So does the drill and tap not work if you were going from auto to 5spd? Just curious because this was the biggest issue with the last 2 swaps my friend did.
Conversion from Auto to 5 speed requires rewelding the tranny bracket (sheet metal) on the frame rail. You should still use the 5 speed Accord mount for this as well. The same drilling and tapping steps will be required.
[Modified by 2point6, 2:23 PM 1/7/2003]
HUH??????? i have a 4th gen with a 95 h22 motor and tranny, and nothing needed to be modified to put the motor in. i have taken the tranny out 4 or 5 times, and it goes back in, mount and all no problem. if you have problems, just unbolt the rear mount from the tranny, and put the motor in, then get under there and work it back in and bolt it up. real easy
You might want to try a 95 lude 5spd trans mount. It attaches to the frame the same as the 4th gen accords but it attaches to the tranny the same as the 92-01 ludes. That is what I used for my 01 h22 into my 93 accord
You should not have to re-weld anything when doing this swap. You should be able to find parts that will fit.
If it was a 5 speed car (like I asked in my original post), then the stock Accord brackets will work. You will just have to drill and tap the factory bosses on the Prelude tranny.
[Modified by 2point6, 7:04 AM 1/9/2003]
Yes, I did a auto to manual conversion and I did not have to re-weld anything. I used a 95 lude 5spd tranny mount. The attachment point on the body of the accord is the same for both auto and manual( as any mass produced car is, prelude as well). The prelude tranny studs are in a different pattern than the accord. Re-welding is an option but it is not the only option. My point is that different tranny mount will work. If you can weld, if you cannot get a different mount for whatever reason, or if you want to weld, then by all means do. I am just giving another option.
I do see part of your point, however, the cars even being "mass produced" (auto to manual) do have different sheet metal brakets. The part numbers are (this is the same for all 4th gen accords) manual bracket (sheet metal) is 60831-SM4-300ZZ, and the Auto # is 60832-SM4-970ZZ. I will try to get pictures as well. They are in 2 different locations. The tranny mount you have in place may work, but I would like to see the alignment of your engine (I am suggesting this objectively, Because if you have a solution, The 95 mount would be a hell of a lot easier to do than to weld) can you post a pic? I am skeptical, but I can be edjucated.
[Modified by 2point6, 9:22 AM 1/9/2003]
I am saying that the metal bracket that is welded to the frame is in the same spot on both auto and manual. The rubber section of the mount is also the same. I know that the bracket that bolts to the trans is different( I tried to use the 5spd bracket before I found the prelude monut). When I put in the prelude mount it bolted up perfectly. My engine sits beautifully, I will try to find some good pics and post them.
You are right, I am wrong. I thought they were the same. I would like to know how different they are. It seems to me that there cannot be too much of a difference in placement.
When changing the mount from auto to manual, I have had to relocate the bracket aproximately 1" lower on the rail and approximately 2" foreward. There is quite a difference, that is why I would like to see your set-up. If you found a easier way (that will keep the engine square) then I am all ears...
I will post pics by the end of the weekend at the latest. I found some last night but I do not has access to a scanner at work.
I am a little curios about something, was the car you did the swap on damaged? I have never heard of anybody else having to re-weld that bracket.
Also, what year engine and tranny did you use? Was it JDM or USDM? What year accord was it.
[Modified by 93acclude, 3:55 PM 1/10/2003]
my friend has done two, both were JDM motors into a 93SE coupe and a 91EX sedan. Both were auto to manual as well. Not sure what year JDM H22a's but they were OBD1 with LSD
Maybe the transmissions are different between JDM and USDM. I used a 2001 H22A4 and a 93 ex. I did not have any problems making the mount fit. It just seems that too much is being done to get the mount to fit. Moving the bracket and tapping new holes seems extreme, but, there could be a difference in the bell housings that I do not know about.
[Modified by 2point6, 9:53 AM 1/10/2003]
