How high do you rev (stock type s)?
Old Jan 7, 2003 | 05:18 AM
epren's Avatar
Default How high do you rev (stock type s)?
How high can you set your rev limit safely for a stock type s?
What mods needed rev higher safely??
Old Jan 7, 2003 | 05:22 AM
Deadly-Lude's Avatar
Default Re: How high do you rev (stock type s)? (epren)
to rev higher you need to first do your head. i.e. better vlaves, valve springs, and retainers. Next you will need to go to work on the bottom end. get your pistons, rods, and balnce everything to your crank. oh and dont forget your pinston rings and bearings and it wouldnt hurt to get some arp rod studs..
Old Jan 7, 2003 | 05:25 AM
aklucsarits's Avatar
New User
The Japan-only Type-S Prelude has the same redline as a "regular" VTEC Prelude - 7400rpm with a 7600rpm fuel cut.
Andrew
Old Jan 7, 2003 | 05:42 AM
trahsub's Avatar
I've done no work to my internals on the engine and I seem to be able to go past redline - about 7800 RPM. Does anyone else notice this or could my limiter be broken?
Old Jan 7, 2003 | 05:48 AM
New User
Default Re: How high do you rev (trahsub)
The stock tach gauge is optimistic. If you had the actual RPM reading like you get on a V-AFC, it is 7600rpm at the cut.
Andrew
Old Jan 8, 2003 | 01:17 AM
epren's Avatar
Default Re: How high do you rev (aklucsarits)
thanks for the info.
so i should just stay with my stock rev limit??
wat about if i get it chipped and go a bit higher, how high do you guys recommend?
Old Jan 8, 2003 | 05:44 AM
Jason kiDD's Avatar
Default Re: How high do you rev (epren)
Doesnt matter you stop making power after like 7k so I wouldnt recommend revving any higher on stock internals.. Just try to make more usuable power within the whole RPM band and you will do fine..
Old Jan 8, 2003 | 06:38 AM
Honda318dx's Avatar
Default Re: How high do you rev (Jason kiDD)
This makes perferct since.. Overreving only helps in autox/roadracing, where you don't want to waste the time shifting, when your going to have to slow down a second after you upshift..
When I was on the dyno, my car would easily rev to an indicated 7900 on the factory tach, but would only go to 7500-7600 on the dyno tach
Oh yea, look at the SMSP header graphs, power does not fall off
Old Jan 8, 2003 | 07:16 AM
Jason kiDD's Avatar
Default Re: How high do you rev (Honda318dx)
Just to be clear didnt say that power falls off, but using the same dyno graph as an example hp levels off after 7k and torque actual declines after that as well. And this is on a slightly modified lude...
GC106XT
Feb 23, 2014 06:48 AM
Blk93Sihatch
Feb 2, 2006 01:12 PM
JhorickJFL
Feb 22, 2005 10:05 PM
SohcVtecCrix
Nov 19, 2002 01:12 PM
90teg
Aug 1, 2002 10:41 AM
