FS: JL w6 12 inch Subs
Old Jan 7, 2003 | 05:11 AM
x916's Avatar
Default FS: JL w6 12 inch Subs
These are used for about barely 1 month..the reason why they are being sold is becasue the car is being sold and there is really no use for them
please make offer for all 3, or 2, or even 1 if you want
AIM voltronx916
Email voltronx916@hotmail.com
Old Jan 7, 2003 | 05:19 AM
Tony Starks's Avatar
Default Re: FS: JL w6 12 inch Subs (VoLTRoNx916)
Would a pair of them be able to handle a 1000 watts mono?
Old Jan 7, 2003 | 07:16 AM
zilverz's Avatar
Default Re: FS: JL w6 12 inch Subs (Tony Starks)
W6'z are 6ohm subs ... you need to run 3 of them in order to run a 2ohm load on your amp ..
Example: if you wire up (2) 6ohm subs .... that puts a 3ohm load on the amp ...
so if your amp is 500watt RMS @4ohm and 1000watt RMS at 2 ohm
the (2) subs will get about 750watts RMS
that is of course unless you have one of the NEW JL audio amps .. which has some funk ohm controls
Old Jan 7, 2003 | 12:42 PM
x916's Avatar
Default Re: FS: JL w6 12 inch Subs (zilverz)
ya what he said
Old Jan 7, 2003 | 10:07 PM
rodimus's Avatar
if you have two JL W6's you have to wire them at either a 1 ohm load or a 6 ohm
load. run 3 of them..i believe either wiring them in series or parallel you can
get a 2 or 4ohm load.
Old Jan 7, 2003 | 10:36 PM
ctr909's Avatar
BANNED
Default Re: FS: JL w6 12 inch Subs (EVOL)
Old Feb 5, 2003 | 03:12 AM
NrG's Avatar
NrG
Default Re: FS: JL w6 12 inch Subs (burp)
damn if those were v2, i would pick 2 up
supracrx
Northern California (Sales)
Aug 5, 2007 01:54 AM
89hbcivicguy
Audio / Security / Video
Mar 3, 2005 09:12 AM
Kingpin748
Jan 6, 2005 02:41 PM
kbplaya
Feb 24, 2004 08:43 PM
