5th gen lude, stock tires 205-55-16, what should be ideal for aftermarket? 205-40-17?
Old Jan 6, 2003 | 08:08 PM
lakerschamp2000's Avatar
Default 5th gen lude, stock tires 205-55-16, what should be ideal for aftermarket? 205-40-17?
is this size 205-40-17 small for prelude 5th gen? if i used them, am i gonna lost any velocity of the wheel. I compare them to stock tires and they seem smaller than stock tire llike 1" . anyway, what size of tires 17" would be the same diameter of the stock tires 205-55-16. please help
Old Jan 6, 2003 | 08:11 PM
Ritteri's Avatar
Default Re: 5th gen lude, stock tires 205-55-16, what should be ideal for aftermarket? 205-40-17? (lakerscha
215/40/17 I believe.
Old Jan 6, 2003 | 08:17 PM
DsITR's Avatar
http://www.miata.net/garage/tirecalc.html
look there
last time I checked my 5th gen has 205/50/16..55's are to tall, they would higher your gear ratio..slowing acceleration.
I have 215/40/17, which are a bit wider and taller than 205/40/17....205/40/17's would give you less traction from a launch but shorter gearing (barely)
[Modified by dsludefosho, 10:18 PM 1/6/2003]
Old Jan 6, 2003 | 09:37 PM
typeSwarrior's Avatar
You should get some fat *** 235/40/17 tires for the Lude...I'm sure they will fit (if not somebody correct me), and your speedo will still be under 1mph different according to that calculator dsludefosho posted a link to.
Old Jan 6, 2003 | 10:11 PM
Prelude_2_NV's Avatar
it also depends how much ur lowered
if ur lowered more than 2" then u'll need 205/40 17, i know they are smaller than the stock diamter but this will aleviate some rubbing problems, if u do get some
if not, 215/40 17 are the ideal size
Old Jan 7, 2003 | 04:04 AM
KGAccord's Avatar
205 45 17 would be best.
Old Jan 7, 2003 | 05:18 AM
Deadly-Lude's Avatar
I had 215/40r17 on my 5g with racing hart cp-35's
Old Jan 7, 2003 | 05:54 AM
stoopid215's Avatar
i got 215/40/17
thegamettt
Mar 26, 2007 03:46 PM
honda_andy
Oct 12, 2006 09:45 PM
ej2_sir
Sep 11, 2006 08:04 AM
classified
May 26, 2006 04:01 AM
mdjplay
Jul 3, 2003 03:28 PM
