Engine swap & gauges question
Old Jan 6, 2003 | 07:58 PM
bLiSS's Avatar
Default Engine swap & gauges question
Hey everyone,
I am wondering, after an engine swap.. what would become of my gauges ? The ones in front of me, such as the speedometer, and tachometer.
Would they automatically 'tune-up' to the new engine's performance ? Or they will be completely out of order ?
I'm in a F22B2 97 Accord, is it the same on any swap on any car ?
Thanks in advance
Old Jan 6, 2003 | 09:24 PM
KTeller8's Avatar
Default Re: Engine swap & gauges question (bLiSS)
it all stays the same
your sensors read the "new" engines performance and adjust accordingly
you can keep your current cluster
no different
Old Jan 7, 2003 | 03:26 AM
KGAccord's Avatar
Default Re: Engine swap & gauges question (KTeller8)
yeah just don't expect it to be too accurate, my V-AFC reads 7,300-7,400 when the tach is around 7,900-8,000 rpm. Some people have better luck though than me.
Old Jan 7, 2003 | 09:29 AM
bLiSS's Avatar
Default Re: Engine swap & gauges question (KGAccord)
What's the V-AFC ? A separate gauge system you add around your dashboard ?
How much are those ? There 'is' a significant difference between 7300 and 7900..
Your own gauge should be more accurate right ?
Old Jan 7, 2003 | 10:16 AM
KGAccord's Avatar
Apexi Vtec Air Flow Converter = V-AFC http://www.apexiusa.com and a simple search will yeild alot about this little thing. I paid $300 for it.
Most oem guages are off about 300 rpm in that rpm range,even ludes that's why they shift at 8K cause in reality they are 7,600-7,700 range which is fuel cut.
[Modified by KGAccord, 7:20 PM 1/7/2003]
BigChris's Avatar
http://www.apexi-usa.com/electronics_vafc.asp
[Modified by BigChris, 7:17 PM 1/7/2003]
hatchback_al
Jul 24, 2004 12:43 PM
racinskittle
Sep 23, 2003 12:44 PM
SCHYBRID
Mar 15, 2002 05:22 AM
