gas pedal is sticking. what do i do???
Old Jan 6, 2003 | 07:36 PM
95accordracer's Avatar
Default gas pedal is sticking. what do i do???
when i drive my 95 accord, the gas pedal decides to stick at random times, shooting the rpm's up. I have to hit the pedal down and let go in order to "unstick" it. how do i make a permanent fix???
Old Jan 6, 2003 | 09:29 PM
iam7head's Avatar
Default Re: gas pedal is sticking. what do i do??? (95accordracer)
check the cable, the bv, the floormat under the padel.
Old Jan 7, 2003 | 01:31 PM
porkfried's Avatar
Default Re: gas pedal is sticking. what do i do??? (iam7head)
it could be your throttle body getting stuck... possibly... id spray the pivot with WD-40 or some lubricant. it could also be the cable sticking inside the housing... thats all i could think of anyway
Old Jan 7, 2003 | 02:51 PM
TeamEndlessMotion's Avatar
Default Re: gas pedal is sticking. what do i do??? (porkfried)
or your just screwed...hope u have good brakes...haha
Old Jan 10, 2003 | 08:28 PM
Default Re: gas pedal is sticking. what do i do??? (TeamEndlessMotion)
ha.............ha
Old Jan 11, 2003 | 07:43 AM
Kazmans94cord's Avatar
the same thing happened to mine...the "fins"(sorry i forgot the name of them) in the tb were all jacked up for some reason and it was causing my pedal to stick...all i had to do was change the tb out and it was fine.
VietCloud7
May 6, 2008 04:46 PM
Yeung
Jun 3, 2004 09:12 PM
midorigreen.
Mar 16, 2003 07:40 AM
Cat
Sep 30, 2002 06:48 AM
sa21199
Jan 4, 2002 03:25 PM
