what camber kits are you guys using?
ingalls in front and sprints in the rear for my car.
for my gf's car, i put on a set of skunk's and i shimmed the rear. both worked out fine.
I am useing some kind of wanybe skunk upper control arm I had to press in the balljoint. It doesn't work too well so I am going to get the skunk one. I was told the rear doesn't need a camber but if it is that low bolts and washer's will do the trick.
I use SPC on all our cars /racecars
The R gotr the front ball joints and reaer ez arms
and the civic got the front ball joints and rear lca and uppper ez arms
cool,cause i usally go to a place and they heat up the spindles and bend them as far as possible but the problem is i will be getting some new brakes and i want some adjustibility to it
I just use washers and keep the ride height reasonable.
I the old days I have "influenced" knuckles also, but not on a drag car.
scoobyghost
Aug 17, 2003 09:06 AM
