need help wiring horn to momo wheel
Old Jan 6, 2003 | 04:54 PM
Lei Siew Long's Avatar
Default need help wiring horn to momo wheel
had my momo wheel for about 4 years and never bothered to wire the horn. what, i'm planning to do is, find the horn wire from the airbag harness with a test light and use that to make contact to the hub of the momo wheel.
but, i'm not sure if i have the right wire because when it makes contact with the hub and the button is hooked up, when the connection is made, the only thing i hear is a clicking noise everytime the horn button was pressed.
here is a link to the method i'm following:
http://www.urbanasian.com/pcin05.php
Old Jan 6, 2003 | 06:06 PM
Default Re: need help wiring horn to momo wheel (boostedeg6)
ttt
Old Jan 7, 2003 | 06:27 PM
a little help...please
Old Jan 7, 2003 | 06:54 PM
cplessl's Avatar
ok, the january 2003 sport compact car had a little explanation on how they did it on their project eg, the wire they used from the airbag harness was the upper left hand wire on the plug (with the keys that only let you plug it in one way facing down), someone can probably scan it.
Old Jan 7, 2003 | 09:57 PM
Default Re: need help wiring horn to momo wheel (cplessl)
a scan or a little more help would be great.
are you referring to this harness?
Old Jan 9, 2003 | 03:00 AM
ttt
Old Jan 9, 2003 | 01:52 PM
all stock's Avatar
bump.
Old Jan 9, 2003 | 03:22 PM
RSZero1's Avatar
Default Re: need help wiring horn to momo wheel (edrop27)
IM EG6Si, he knows the exact part you need to do this very easily, there is a stock part. he helped me out with mine and I couldn't be happier...VERY EASY!
Old Jan 9, 2003 | 04:28 PM
Default Re: need help wiring horn to momo wheel (RSZero1)
thanks edrop for the bump and thanks for the info rszero. i'll IM him now.
Old Jan 10, 2003 | 10:25 AM
ttt
Old Jan 23, 2003 | 01:32 AM
Typel2's Avatar
what stock part?
Old Jan 23, 2003 | 01:39 AM
Default Re: need help wiring horn to momo wheel (Typel2)
eg6si was kind enough to provide the link and pictures necessary for this task.
here it is:
https://honda-tech.com/zerothread?id=273474
Old Jan 25, 2003 | 03:29 PM
all stock's Avatar
thanks! bump again.
crdcz03
Sep 10, 2020 09:23 PM
Hatorade
Apr 20, 2010 01:05 PM
JDM-EJ1
12
Dec 30, 2005 03:02 PM
HYBRIDHATCH92
Sep 7, 2002 07:10 AM
