GSR owners w/ ITR LSD....need info!
Old Jan 6, 2003 | 02:34 PM
NeoGSR's Avatar
Default GSR owners w/ ITR LSD....need info!
I'm considering a ITR LSD tranny for my stock '95 GSR. how many RPMs in 5th gear cruising at 70 or so....i've heard the ITR LSD is bad on the highway....
how do you like the ITR?
also, what do i need to swap the tranny? or is it a bolt up?
Old Jan 6, 2003 | 02:37 PM
APEX i GSR's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (NeoGSR)
the tranny bolts right up
no other mods
great upgrade
Old Jan 6, 2003 | 02:39 PM
NeoGSR's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (APEX i GSR)
even a JDM?
Scary1109's Avatar
the lsd doesn't change the rpm of the engine. i think you are thinking about the itr final drive. the final drive and the itr lsd are not related. if you just use the itr lsd, you won't notice a change in rpm, just a change in grip.
Old Jan 6, 2003 | 02:41 PM
NeoGSR's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (Scary1109)
can you use the final drive unit off the gsr?
i was planning on using the 4.785 final drive unit....good idea or just use the gsr?
Old Jan 6, 2003 | 03:07 PM
GSRwBOOST's Avatar
uh.. other than gearing.. there wont be much of a change...
if you can afford to spring for a quaife, get that and slap that into your GSR...
Quaife was the second best upgrade i ever did.. (turbo was number 1)
Old Jan 6, 2003 | 03:29 PM
If You Slip You Die's Avatar
ITR LSD Quaife LSD
Old Jan 6, 2003 | 09:32 PM
NeoGSR's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (lilxjoker)
what rpm do you run w/ the 4.785 final drive unit? at, let's say, 60...?
Old Jan 6, 2003 | 09:46 PM
Big Teggie's Avatar
This should help
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old Jan 7, 2003 | 10:05 AM
NeoGSR's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (Big Teggie)
Excellent!!!!
thanks alot!
Old Jan 7, 2003 | 12:29 PM
gsxr's Avatar
can i use the bolts off of my stock ring gear for a jdm itr lsd? the reason im asking is b.c. one of the bolts is missing of a jdm itr lsd i bought.... tia
Old Jan 7, 2003 | 08:04 PM
Turismo's Avatar
Default Re: GSR owners w/ ITR LSD....need info! (gsxr)
Bolts are the same.
SupaFly_Honda
May 12, 2004 05:12 AM
gsr-2nr
Dec 3, 2003 04:07 PM
wizzards581
Jan 8, 2003 04:38 PM
CBM99Lude
Aug 13, 2001 02:49 PM
