83mm bore on stock sleeves on a B18A1
Old Jan 6, 2003 | 02:04 PM
JeremyL's Avatar
Default 83mm bore on stock sleeves on a B18A1
would it be possible? and would it be safe to run 8+lbs of boost on such a bore with stock sleeves?
Old Jan 6, 2003 | 04:00 PM
integradoc's Avatar
Default Re: 83mm bore on stock sleeves on a B18A1 (JeremyL)
what pistons and rods do plan on using? I don't know with the boost but my shop manager did the 83 mm on a b18a1 and ran it all motor with the intentions of running NO2 to it. I would try to contact JE pistons or eagle rods to see how that app will work for you
Old Jan 6, 2003 | 04:15 PM
JeremyL's Avatar
Default Re: 83mm bore on stock sleeves on a B18A1 (integradoc)
well i found a guy selling a set of arias pistons with rings for $300 but theyre an 83mm bore...i think that might be too big for stock sleeves boosted
Old Jan 6, 2003 | 04:18 PM
integradoc's Avatar
try contacting arias directly and see what they recomend, wish I knew more about it so I could help more. good luck
Old Jan 6, 2003 | 06:26 PM
onetwothree's Avatar
The most I think you can overbore any b-series block is 82mm. And that's pushing it. theres no way you can overbore it to 83mm without resleeving it.
Old Jan 6, 2003 | 07:21 PM
threatcon13's Avatar
New User
Default Re: 83mm bore on stock sleeves on a B18A1 (onetwothree)
don't bore it that much out unless you are going to sleeve it. .25 is the max limit recommended by helms.
Old Jan 7, 2003 | 07:40 AM
X-Mazda 3 Racer's Avatar
Yeah, they are right. 83mm is just not doable on a stock block. For a boosted app., I wouldn't go over 81.5 mm. If you sleeve it, you can go 83mm no problem!
Old Jan 7, 2003 | 07:48 AM
JeremyL's Avatar
Default Re: 83mm bore on stock sleeves on a B18A1 (GoldenEagleMfg.com)
yeah i didnt think so i just wish i could find a good set of low comp forged pistons for $300 or less w/rings
Old Jan 7, 2003 | 09:14 AM
New User
do shxt right if youre gonna go turbo...u dont want like 2 hundred dollars costing you a whole motor.
Old Jan 10, 2003 | 01:36 AM
Timmayeg's Avatar
New User
81.5 and he wanted to run n20, just to clear that up
Old Jan 11, 2003 | 02:50 PM
integradoc's Avatar
Default Re: 83mm bore on stock sleeves on a B18A1 (91_ED6_Civic)
Oh ya, my bad it was 81.5 thanks man!
BoOstedN1ck
Aug 8, 2009 05:22 AM
redcivic44
Feb 26, 2006 04:33 PM
SpoolnByYou
Dec 19, 2005 02:28 PM
turbo89civicb18hatch
Nov 8, 2004 04:42 PM
MisterB
Jan 15, 2002 11:26 AM
