55 hp shot (ZEX)
i know this is in another post i have read it but i have an ls with 110000 and would like to install zex the 55 hp shot would be fine for me, i know that i would need to get colder spark plugs, but what else, do i need to retard the engine, get a better fuel pump, or redo the timing? and with 110000 even with colder spark plugs and decent comnpression how safe is it
thanks for any feedback
If i were you, I'd see how i liked a 35 shot. It should be enough to satisfy ya. the larger shot would probably be ok, but you'd definatly want to look into the plugs and possibly a fuel pump just because of the age on yours. your ignition timing, if you went the 55 shot route, might need a little adjusting. try a 35 though... see how ya like it and how the car handles it. be sure to run 93 when spraying.
-Erik <--- who was pleasantly suprised what a mere 35 shot did on the LS
**** a 35 shot that **** is a waste of time, retard your timing 2 degrees, get colder plugs and a fuel pump if you wanna be really safe, I have been using nitrous for 4 years man and have had all types of kits, and let me tell you a 35 shot is not good for **** unless you wanna run it in your intercooler and thats about all that **** is good for!
the only reason i suggested a 35 would be to get started and see how the car reacted to it since he was curious as to how the mileage would effect it. i agree though, the 55 shot would be nicer.
-Erik <--- who last sprayed a 125 and it felt GOOOD!
