2.5 or 3 inch exhaust???
Old Jan 6, 2003 | 12:34 PM
fire7882's Avatar
Default 2.5 or 3 inch exhaust???
I currently have a b16 with all the boltons and stock cx exhaust. I plan to go turbo (built 1.8 block w/ b16 head) in a year or 2 and shoot an 80 shot dp nitrous until then. My question is should i go ahead and run 3" exhaust with a 2.5 inch header collector and 2.5 inch muffler or would this setup rob me of power.
Old Jan 6, 2003 | 12:44 PM
Captain_Kicker's Avatar
Default Re: 2.5 or 3 inch exhaust??? (fire7882)
well i dont think its a real question of how much power you are going to lose involving hte back prssure..rather how far your car is dropped and will a 3" exhaust fit with room to spare...i personally dont beleive that an abundant amount of power will be lost...possibly 2-3..however the b16 is already a built motor with some pretty raw stock headers...so my recommendation woulld be if you have the room go 3" but it not a 2.5" will be comprable
Old Jan 6, 2003 | 01:42 PM
OG LL C's Avatar
New User
For a turbo b16 I would go with a 3" exhaust. If your staying allmotor than 2.5" will be fine.
Old Jan 6, 2003 | 01:47 PM
STEALTHMODECOUPE's Avatar
Default Re: 2.5 or 3 inch exhaust??? (bishop)
2.5 inch is fine..just because its bigger doesnt means its better..
adaM
Old Jan 6, 2003 | 01:52 PM
LsVTeCTuRBo17's Avatar
There are a lot of contributing factors as to what size you run. The main factor is what size of turbo you will be running and how big the exhaust side will be. A T3/T04 will be sufficient with 2.5" exhaust, you dont want to lose backpressure however, but if your gonna step up to the plate and get a full T04 you gotta have a 3" exhaust.
[Modified by LsVTeCTuRBo17, 2:52 PM 1/6/2003]
Old Jan 6, 2003 | 02:11 PM
fire7882's Avatar
Default Re: 2.5 or 3 inch exhaust??? (LsVTeCTuRBo17)
I want to run a fairly large turbo so i think i'll want a 3 inch exhaust when i go turbo. My main concern is weither it will decrease the performance of my current all motor setup evin if i have a 2.5 inch muffler and 2.5 inch collector.
Old Jan 6, 2003 | 02:15 PM
Yes it will affect your performance on an all motor setup. Do not get 3" exhaust on your allmotor setup unless your prepared to lose backpressure.
Old Jan 6, 2003 | 02:20 PM
IS3Fifty's Avatar
3 is for turbo only!!!! dont use 3 for NA, youll get turbo lag without the turbo.
Old Jan 6, 2003 | 02:32 PM
crxrookie's Avatar
Default Re: 2.5 or 3 inch exhaust??? (purek9hybrid)
that set-up is too big for N/A. you will loose to much backpressure and definitly hurt your performance. its not really gonna be a huge loss, so as long as u know that u r going turbo i would get that set-up. with turbo, the bigger the exhaust the better, so get whatever u can squeeze under there.
Old Jan 6, 2003 | 03:13 PM
fire7882's Avatar
Default Re: 2.5 or 3 inch exhaust??? (crxrookie)
wouldn't the 2.5 inch muffler provide the backpressure or does it not work like that.
tarzzan
17
Jan 22, 2013 11:57 AM
vg7z
Jun 2, 2006 07:01 PM
hYbRiD EeEkAy
Dec 13, 2005 09:12 PM
n0pinitr0us
Dec 23, 2004 09:43 AM
BlazinEK
10
Nov 3, 2004 09:50 AM
