Oil Squirters With LSVTEC?
Old Jan 6, 2003 | 10:25 AM
96-EJ6 B18C's Avatar
Default Oil Squirters With LSVTEC?
Is it possible to use the oil squirter setup with the LS block? Or is it more work than its worth? Any help is much apreciated.
Old Jan 6, 2003 | 10:27 AM
vivid02's Avatar
Default Re: Oil Squirters With LSVTEC? (LSVTECPLAYA)
In my opinion it is more work than it is worth if you are not planning to be rev above 8000 RPM on a daily basis.
Old Jan 6, 2003 | 10:31 AM
nerdsports's Avatar
if u look into a vtec block, u'll see that the oil squirters are screwed into the block, however the oil passages are INSIDE the actual block... if u do it, it would prolly be with metal piping thats like 1/8" and completely CUSTOM!! anythings possible...... just takes time and thinking...............
this kid i kno has an lsvtec, running pretty strong... been like 20k miles i think......... pretty reliable. he also revs to 9grand!!!!!!!!
[Modified by nerdsports, 7:31 PM 1/6/2003]
Old Jan 6, 2003 | 10:49 AM
Default Re: Oil Squirters With LSVTEC? (nerdsports)
What all does your friends motor have done too it? I'm hpoing to be able to rev mine that high as well. I'm planning ITR pistons and some valvetrain goodies. Maybe even an indivdual throttle bodie setup.
93FastLs
Aug 3, 2005 12:04 AM
al'motormadness
May 12, 2003 12:31 PM
B16A1-EF9
Dec 7, 2002 03:27 PM
One8Hatch
Oct 18, 2001 12:24 PM
